No excuses, AMOF I'm stoked.
Although these are uncorrected #'s, (I'll take um as high as I can find un, hehehehe)
To be soooooooooooo close to my Goal, ON 14 DEGREES OF TIMING, is just amazing
(14 and 16 degrees were pretty much the same)
Although I rushed to install the n20 plate this morning and went there ARMED AND DANGEROUS, (woo hoo) what you see here is after a lot of work, at first the AF was well into the 13's, and
totally unaccetable to Sal and Myself to even think about adding 150 HP.
(if we're running out of fuel now, no way it can flow the xtra fuel for 150 HP of added n20)
ESPECIALLY WHEN THE PROBLEM IS PUMP RELATED
So unfortunately no N20 Runs, AMOF no Race Tunes either, I left without a switch even installed
in the SCT, (yes we switched from my Diablo to my SCT Chip).
At least I can FIANLLY WOT it and feel safe, (still running a tad lean on the top end, but I'm ok
for short blast) WOO HOO..... So FOR NOW only a 24/7 around town tune for pump gas.
The Maf Extender and 50lb Injectors worked perfect, no where near 5 volts, and the Injectors
have plenty more to flow, the problem is simply we're not getting enough from the Pumps. Unfortunately Sal is out of pumps this second, so we have to order them and install them before
we can go further.
Considering I'm @ where I was with 4 + 2 + Mother of Ports + 75 N20 + 19 Degrees,
I AM TOTALLY SATISFIED (especially for a 14 - 16 Degree pump gas tune)
I got DAM NEAR 600 FT lbs of Tq already, WOO HOO
This frigging Magnum Screams like you can not imagine, if you never heard one on a Dyno, do yourself a favor and listen to one, WOW. Sal let me sit in the pass seat and watch the gauge
to make sure there was no slipping, hehehehehe...... CAN YOU SAY 22lbs OF SCREAMING
WHINE AT WOT TOP END :shock: I'd buy this Magnum ten times over just for that wonderful scream, but having the power I use to have on Nitrous, WITHOUT NITROUS
IS PRICELESS......................
Not quite there yet my Frineds, BUT WE SURE ARE GETTING CLOSE
THANKS SAL / PSP, YOU ARE THE MAN........................
:cheers:
Sal sure is having a lot of fun with Turbo Beast, he even put street tires on it, and drives it around now, WOO HOO
Man I can still smell the rubber on me, hehehehehe
Got to fly for now, Movie time.....................
we can go further.
:cheers:
