Status
Not open for further replies.
1 - 1 of 1 Posts
This is to help everyone see what options add power and what does not.
NAME-----   DYNO #'S HP / TORQUE--    H/P  TORQUE CLUB --  MODS
chillfactor --------746.90 / 970.98------700/900----????
fomocofan-----------650.75 / 721.29 --------600/700------------A, B, C, CA, D, E, F, FP, FI-60, G- 3.73, H, J= SCT, K, L= 8, M= SCT, 0= 116, P, S, T, TB= ACCUFAB, U= 3.0", V, W, X= BTS
RAMAIRSVT-----------649.5 / 755.5-----------600/700------------ FTVB,A,B,C,D,E,F,H,HP,K,L10,U2.75,M,MS,O,P,R,S,T,TB,V,W
DonsBolt--------------634.91 / 762.93--------600/700-------------??????
camcojb --------------621.5 / 706.7 ----------600/700 ------------B, A, E, F, H, I, T, J, K @21 psi, T, FI 60#, FP, CA Stage II
bobver -----------586/650-------------------500/600--- L(8),JLP Built Motor, H (Stage 3 Cams), JLP Afco  Heat Exchanger, V (2800), BAP, M
airtroop01-------------563.32/652.94------500/600-----??????????
Ryan Allen-----------555.4 / 661.5---------500/600----------?????
03LightningRocks----531.72/622.97-------500/600--------HP,F,L**,U**(total of both is 16 lbs),T,W,D,S,E,A,M,K,V,B,O,X,Z
Rob_02Lightning-----501.37 / 615.36---500/600-----FTVB,F, C, L(4), U(2), Q, T, PB, MS, N(75), 2" Drop shackles, D, TB
TSDuke--------------515.44 / 620.24-----500/600-----FTVB,A,B,E,F,J,K(3.2" pulley),L8,T,TB,W
Highlander-----------508.95/577.96------500/500----B, E, F, H. J, L(8), Q, SK, T, W
Pitch Black-----------516 / 593------------500/500----C,F,L(?),T,W,E,A,M,K,I,H,B
Whip ------------461.71 / 535.46 ------------400/500--------------C F 4L 2.7U T W E A M Z
BoostinSvt954 -----425.5 / 530.8-------------400/500----------I, E, C, L(4), U(2), T
SlowSVT95 -------422.92 / 537.94------400/500-------??????
UNDRPSI------421.9 / 525.4------400/500----------FTVB, C, D, E, F, L (4), S 1100lbs F spring 2" R shackles, Pan Bar, Hellwig sway bars, QA-1's, TB,W
lightningkid  -------------404.74 / 529.90-------------400/500-----------L(5), U (2.8), FTVB (JL), J
03WHITELIGHTNIN-----------404/506----400/500----L(4), J, F
gokorn1-------------400.8 / 504---------400/500--------2002 FTVB, C, F, L(?), E
rumrunner----------397 / 484  ----------300 / 400-------F, L4, FTVB, J
silversvt-------------396.6 / 489 --------300 / 400-------F, I, T, J
RhinoHD------------390.90 / 475.77-----300 / 400-------J, E, F, L(6)
99BlackBeast------387.9 / 444.3 -------300 / 400-------G, ?????
Boss Hoss---------386.18 / 479.44--------300/400--------2003 Harley, L(6), CAI, J
Avalanche-----------350.6 / 466.8-------Stock--------F
Mods Legend:
FTVB= Factory Tech Valve Body
A=Headers
B=Bottom End Work
BAP=KB Boost A Pump
C=Chip
CA=Cams
D=Drag Tire
E=Muffler/Catback Exhaust
F=Filter/ Cold Air Intake
FP= after market fuel pumps i.e. 255's
FI=Fuel Injectors #
G=Gears
H=Heads/Cams Work
I=Upper Intake Work
J=Microtuner/Predator/Reflash/SCT and Proracer
K-Blower Kenne Bell
L=Lower Pulley (Size)
M=MAF
MS= Multi Spark Ignition
N=Nitrous Oxide (Shot Size)
O=Race Fuel
P=Power Cooler
PB = Plasma Booster
PT= Ported Throttle Body
Q = Ported Eaton (any version)
R=Weight Reduction
S=Suspension
SK= Shift Kit
T=Throttle Body
TB =Traction Bars
U=Upper Pulley (Size)
V=Conveter
W=Water Pump/Electric Fan
X = Transmission ( I.e. Monster Box, Level 10. etc)
Z=Aftermarket Supercharger (other than Eaton or KB)
Y= Homemade mod (Explain)
1 - 1 of 1 Posts
Status
