21 - 40 of 61 Posts
11 second street truck
2001 Ford Lightning
Discussion Starter #21
542536
542537
This basically brings me to Summer of 2017. I drove the truck for that year. Spring of 2018 I left for a little over a year so the truck sat.
Summer 2019 I got home from Virginia, got divorced and used the truck as an outlet.
2001 Ford Lightning
Discussion Starter #22
Im missing a few pictures here but you'll get the point
Pulled the bed to install stifflers long bars
hotchkis 2.1 shocks
fore fuel hat
WMS fuel lines
fore regulator
metco rails
ID1050X injectors
DW300 fuel pumps
The plan was to run the kenne bell on E85 and shoot for 600-ish
When the KB came off I felt it was making a noise I didn't like. So I bought a 2.9 whipple.
542538
542539
542540
542541
Sadly the first start of the whipple proved their gasket is ass, and you should just use RTV lol
This video is titled first start, but its actually the first start after the first start
Just a funny video of working out the e85 cold starts with Eric
Reactions: NMSVT
Really enjoyed your the thread Dusten 👍 keep the content coming!
What's your ultimate goal for the truck? Are you where you want the truck to be as it stands now?
2001 Ford Lightning
Discussion Starter #24
On the E85 tune we run enough boost I had to replace my boost gauge
542542
I drove the truck for the short remainder of the summer and like we all do, tore it down for mods in the winter.
some SM0304's with 295/35 555g2's and 305/35 555r's in Hallister bronze were spec'd
542543
542544
542545
542546
Since you can't powder coat plastic the center caps were taken to my painter.
542547
542548
A few missing pictures here. I ordered stifflers lowers and belltech shackles because I wanted the truck to down on the 20s better.
I did a write up here for installing stifflers arms and the hotchkis shocks together. There are probably pictures there.
542549
542550
2001 Ford Lightning
Discussion Starter #25
Spring rolled around and I got laid off for covid. I decided a nice project would be to upgrade the valve springs. Me and Eric had fought a "pop" in the truck when it transitions to boost for years.
Well I thought maybe a weak valve spring was my issue after talking to Kenny. We found out my old trickflow heads had bad springs from trickflow.
Sadly, when I tore the truck down to do the springs we found this
542551
542552
So that lead to this
542553
542554
542555
Fun fact.... here is why you don't use the cast trigger wheel
542556
I ordered up some custom todd warren cams
542557
Ordered up ARM 1-7/8 headers and 3" exhaust
542558
New headgaskets, timing components, and other odds and ends and the motor went back in the truck.
542559
542560
2001 Ford Lightning
Discussion Starter #26
542561
Decided to also delete the AC
542562
I totally fucked up here and installed my passenger cam 180* out.
I fixed the issue and even with the cams timed to ford spec I had an issue with fuel trims bank to bank.
So I ordered some comp gears, tore the motor down again and with the help of Marty Dialed the cams in. The passenger cam was 4.5* off
2001 Ford Lightning
Discussion Starter #27
Got all the tuning done with Eric and decided to go racing.
Local alignment shop couldn't get the truck aligned. So of course, more parts.
Stifflers uppers
542563
And we go racing
This is my street tune, full weight. 4750lbs with driver
Only change is rear tires.
542564
542565
The cams are much milder at idle than the old ones
Pump gas drive by
E85 cold starts dialed in
And the race
2001 Ford Lightning
Discussion Starter #28
So at this point, the 20's look retarded with stock brakes behind them
A call to Todd @ tce solved that issue.
15" front rotors
6 piston calipers
Hydroboost with custom lines(thanks to Daemon for the write up)
542566
542567
542568
542569
542570
2001 Ford Lightning
Discussion Starter #29
And that is basically caught up.
I plan to add a CTS3 and 2 gauge pod to the truck and get rid of my aeroforce.
I have also started collecting parts for a 6 speed swap, but that's a long range plan.
2001 Ford Lightning
Discussion Starter #30
I kind of spelled it out in the last post
I want to get it on the dyno and get a sheet that says 700hp or more
I need to get back to the track this summer and get a 10 second slip
And then just drive it. There isn't much left to do. I need to find a project for my daughter so we can start working on that.
Thanks for posting this thread man. Hopefully I can do the same some day
Reactions: Dusten
This is a awesome build thread!! Really enjoyed it like how you were able to remember the dates etc. Threads like these make me hopeful of the day i can get back into it
15" front rotors
6 piston calipers
View attachment 542567 View attachment 542568 View attachment 542569
Coming along nicely. I hope to get this far with mine someday. Also thanks for the shout out for the hydroboost thread! But u spelled my name wrong. After your 1/8 mile pass and time im sure a 10.xxx in the 1/4 sld be no problem. Good luck.
2001 Ford Lightning
Discussion Starter #34
I don't for see an issue getting 10s. Just nee the track open.
Reactions: Leeproctor83
Should be in the 10s easy. As for the 6 speed swap... Why?
2001 Ford Lightning
Discussion Starter #36
Why not?
I don't drag race. I went once last year. The last time before that was like 2014.
It'll make the truck completely different which it needs. It's getting stagnant after 11 years of ownership.
I like having a manual for occasional driving.
The only downside is "it'll be slower"
local painter
2001 Ford Lightning
Discussion Starter #38
Harder to launch. Slower shifts. More shifts before the finish line.
always impressed sir.
Reactions: Dusten
Great write up and pics!
21 - 40 of 61 Posts
