This thing has so many capabilities from auto to manual to line pressure and tps- to gear selection. You can change the shift points to anything.
Absolutely. I'd certainly consider picking one up if some of the programming guesswork is done, but I would be afraid to burn the cash otherwise (not knowing whether I could make it work in a reasonable amount of time/ frustration).you would need the controller to untilize them.
I can send you some files. They come with pre loaded 4R100 lightning files if you buy the controller for 550 or so.Absolutely. I'd certainly consider picking one up if some of the programming guesswork is done, but I would be afraid to burn the cash otherwise (not knowing whether I could make it work in a reasonable amount of time/ frustration).
