motor replacement
If I was going to be crazy, I'd stick in a bored and stroked 460 for a 610 cu/in. Then use a Hampton 10:71 blower. Turn it for 14 PSI and no intercooler needed as it turns slow and heats the air way less than a speeded up whipple. You can get rid of all that cooling system too. (Pump, radiator , surge tank and hoses.) saving maybe 15 Lbs. If you needed a little more kick, use a dry shot of nitrous into the intake on top of the blower. Run injectors in the factory place. Downside? You need to remove the blower to change plugs.
I built one for a ski boat. It was scary.
