People with corbeau seats.
What bolt did you all use to install stock seatbelts?
TIA!
TIA!
Ahhhh so I have to get my own bolt I was like how do i get the stock bolt for the seat out.There are 2 sizes. 1 for the seat and 1 for the seat belt at the floor. Best i can remember anyway. Its m10x1.5 for the seat and m12x1.75 for the seat belt bolt at the floor.
They bolt them to the floor mounts. However, you need a harness bar for correct placement/height of the harness to be safe. Also, be aware if you try to get your vehicle inspected it will likely will not pass inspection unless you have a cage installed. Reason being is because a harness does not let you be pushed to the side in case of a rollover. It will hold you upright and the roof will crush your head.Ahhhh so I have to get my own bolt I was like how do i get the stock bolt for the seat out.
I have the one for the floor.
Now I also bought the seat belt harnesses. How do I mount them since I don't have a harness bar?
1) if you don't have a harness bar you don't. That's how you get injured.Ahhhh so I have to get my own bolt I was like how do i get the stock bolt for the seat out.
