FYI: Just for the record, while it is still fresh in my mind.....
I drained the transmission pan, converter, blew out the coolant lines, radiator and small air to oil cooler (The complete Lightning trans system)
It took 19 1/2 Qts to refill the system.
(I had heard from 12 to 23 Qts mentioned)
The fluid was brown and nasty smelling, so I wanted to run cheap fluid for a while during the new motor break in period. Then do a change over to synthetic.
Miz
Miz
