1 - 7 of 7 Posts
May the Force be with you
is there anything in particular that I should be looking at replacing/upgrading or going over? Here's a list of parts that were replaced in the last 3yrs since I owned the vehicle:
Intercooler cleaned
Sparkplugs replace
New IC pump
New shocks front/rear
Upper/lower balljoints
Rear Diff fluid changed
Coolant flushed
New T-stat
New Front o2 sensors
New egr valve
Trans flush/filter change (will be done by end of the month)
Pitman Arm
Any other suggestion would be aprreciated
Kyle
Florida>Texas
check brakes and fluid
check coolant
belts and pulleys
Ford Certified Technician
check all your tierods and maybe think about some front hub bearings..... maybe your outer rearend alxle bearings.
Mine were not giving me any problems but I pulled mine out when I replaced my snout seal on my differential and did my slotted rotors, they were worn pretty good at 104,000 miles. seemed to tighten up the feel of the truck but prob just in my head.
Thanks guys
1 - 7 of 7 Posts
