There are more than a handful of us now and I thought we could get a thread going where we can share information about our individual setups, about tensioners, belts, idlers, bridges and whatever. Might be a good idea to lead it off with a poll? But here's what I'm thinking:
My Setup:
Cogs: DMR (Stock Size Upper - 6# Lower)
Tensioner: Reichard Racing Manual Adjust
Idlers: Chickenwings Lipped
Idler Bridge: Magnum Powers
Belt: Gates 1760-8MGT-30 GT2 PowerGrip
Comments: I've had issues with alignment and wearing the edge off the belt so I've been fiddling with washers and spacing to try and keep the belt centered on the tensioner and following PS lipped idler. I guess it cost me a belt a couple days ago. I'm probably going to revert to the Ford Bridge since I think it might help the situation. With the MP Bridge and 3 idlers, you have to be careful with the belt slapping itself under the supercharger cog because they come so close. In talking to Gary this past weekend, he mentioned something about a Kevlar Reinforced belt and I do know that Gates Racing does make a Kevlar Cog belt, but there's no chart available for comparison so I wrote to Gates Racing hope to get an answer. Gates claims that their Kevlar belts are 300X stronger than OEM belts. And there are other companies making Kevlar belts as well.
Typically, our 6# Cog setups use a 69.29" long belt that is 30mm wide, and has a 8mm Pitch and 220 teeth. It would be nice to know what vehicle that belt was originally spec'd for. These belts are basically timing belts and were adapted for our cog sets when DMR first introduced them. Typically you need to input your car make, engine, year, and model to get any info so we can't do that without determining what the belt was used for.
My Setup:
