We have a Ford GT Aluminum block converted to Wetsump for fit in a Lightning/Mustang/GT500 application. This block was one of the orignal GT blocks we converted to wetsump back in 2005-2006 when these were available from Ford Racing. The machine work was done in order to fit a block mounted oil pump, starter pocket, and inspection hole for the converter bolts. These 5.4L blocks are the strongest and lightest version available for your Lightning truck! Unlike the GT500 aluminum blocks that have spray bore lining only measuring .006" thick these blocks have steel sleeves that are over .300" thick! This prevents cylinder wall distortion and provides room to bore the block and leave plenty of meat in the walls. This block is .020" measures 331 cu in and has Mahle Forged aluminum pistons with a 12.5 cc dish yeilding approximatley 9.7:1 compression with CNC ported 2V heads. This shortblock was intended for a Cobra Jet build but we are converting the car to 5.0L coyote platform instead. Rated to handle 1500 HP this shortblock is your holy grail! Requires our custom Aluminum pan and GT gasket for fitment.
Ford GT Aluminum 5.4L Block bored .020" Wet sump converted
Cobra Jet steel forged crankshaft
Manley H beam Rods with ARP2000 bolts
Mahle Forged aluminum Cobra JET NHRA spec pistons
Moly Rings
Speed Pro bearings
ARP main studs (GT spec)
Fully assembled, blue printed, and balanced
CALL FOR PRICING!!!! If you are in the market for this you should be pretty aware of what this will cost. We retail this shortblock with a GT500 block to our CJ customers for $12,995. We are looking to move it so the price is very good for being a GT block. Comes 1 year warrantied as long as there is no detonation.:bigtu
Thanks,
[email protected]
Moly Rings
Speed Pro bearings
Thanks,
[email protected]
