As much as I hate to do this, I am going to put my truck up for sale. I've got a once in a lifetime opportunity to buy a piece of land I've wanted for years, and this is the only way I can make it work. I have owned for 4ish years at this point, and have done most of the mods under my ownership. There are TONS of parts included with the truck.
Truck currently has a Magnum Powers that makes about 18lbs of boost with a 8lb lower, but It just started leaking a bit of oil under high boost out of the snout, so I ordered a Whipple 2.3 before Christmas. It is included in the price!!!
IF I SELL THIS IT NEEDS TO BE IN THE NEXT 2 WEEKS. Please message/call me if you're a serious buyer, I do not have time to waste! I have clean title in hand. I'd take Cash or Cashier's Check only. I am not negotiating, unless you do not want the new Whipple 2.3 and I'll sell that separately.
Here's a pretty comprehensive list of mods/parts included in sale:
Vin #2FTZF07301CA99984
Miles: 98.4k and going
Engine:
MMR 900 Short Block (build sheet listed forged pistons, connecting rods, cobrajet crank, MMR "Stage 2" port Trick Flow Heads stock valves/springs, ARP Main and Head studs, MMR Billet oil pump gears) All new OEM/Ford/Felpro timing components Kinetic motorsports crank saver ARP stud Bullet Custom Cams - 265/271 - [email protected] 050 Int 227 Exh 231 Lift - Int 575 Exh 550 (THIS CAM IS NOT CURRENTLY IN TRUCK, STOCK CAM IN TRUCK CURRENTLY) Ford GT Lifters/rockers OEM/Motorcraft Coils Evap/EGR/Cats Deleted (WILL NOT PASS EMISSIONS OBVIOUSLY) MMR Billet Tensioners Billet Oil Pump Gears Trick Flow Valve covers Moroso Oil Pan
Fuel: 60lb injectors Dual Walbro 255 lph pumps w/ stainless y in tank
Supercharger/Intake: Magnum Powers supercharger (Leaking slightly from snout under high boost, have Whipple 2.3 upgrade already ordered and JC Customs Billet midplate for Whipple 2.3 as well C&L Plenum, Magnum Powers Big O Single blade throttle body SCT 2600 MAF, REM Carbon Fiber Intake
Trans: Precision Industries 2600-2800 rpm billet converter (Rebuilt by Precision Industries less than 1k miles on it Punisher Race valve body (not installed yet, currently a Factory Tech valve body) Moroso Trans Pan/Mercon V fluid (not installed yet, was going to do along with valve body)
Accessories: Billet double bearing idlers (ChickenEars/Very Desirable) Magnum Powers pulley bridge Innovators West Billet Balancer/Pulley hub 8lb lower pulley (10 lb also included brand new)
Cooling Mods: Trick 10 Row Intercooler Coolant crossover mod for cyl 4 & 8 ( From Tim/Hose Hustler along with his 3/4" & 1” coolant lines) Davies Craig Intercooler pump (wired to a relay that runs when ignition/truck on JC Customs Aluminum Intercooler Tank w/ 1" Lines JLP Coolant Tank w/ JC Customs Lid Single pass heat exchanger
Exhaust: 1 5/8" Long Tubes - OBX - ARP exhaust bolts Catless mids Magnaflow catback
Suspension: DJM/Belltech lower control arms (previous owner installed) Hangers/Shackles No front sway bar Driveshaft Shop Carbon Fiber driveshaft Stifflers traction bars QA1 Single adjustable shocks (front not installed yet) JDM Drag Springs Front (not installed yet) Stereo/Gauges: AEM Failsafe Wideband/Boost gauge in AC vent to right of steering wheel Aeroforce Interceptor OBD gauge in steering wheel pod
Interior: Alpine ILX 259 Head Unit with Alpine amp in dash for cab speakers Pioneer 12” shallow sub and Pioneer 1k watt amp CT Sounds components JC Custom Billet door handles Corbeau LG1 Wide Seats, Corbeau dual locking slider brackets, Wide Top Console with Carbon Fiber Lid
Exterior: Carbon Fiber Badges Hi Voltage/Tim Ducket Retrofit Projectors Brand new corners - LMR LED Morimoto Fogs Lund style roll pan (painted myself, not perfect but definitely serviceable) with factory rear bumper included Wheels freshly powder coated gloss black (less than 2 months old) with brand new Nitto 555 295/45/18 fronts and 305/45/18 555RII rears Truxedo Lo-Pro QT tonneau cover BedRug
Parts included at asking price but not installed on truck: HD Circuitry Big 3 Wiring upgrade kit HD Circuitry Raptor E-Fan wiring kit Tamiya TL-01 Lightning parts/trucks x 2 ARP studs/nuts for JC Customs billet Whipple midplate Original Plenums/Throttle Bodies/Headlights/Taillights available but have been sitting outside, free with truck 3 03/04 wheels 1 20” rep wheel Volant Intake Cruise Control module RaceStar Chrome 15x10” Rears and 17x4.5” fronts included. Have tires in decent shape but old
Call/Text me at 9o8-278-4676 or email at [email protected]
Engine:
