1 - 12 of 12 Posts
I have a set if bogart rt's 16x4.5 with 28' tire and 16x10.5, what do you guys think on driving them on the street occasionally?? I've heard they could bent or crack??
· Premium Member
They really aren't designed for street use. You can actually bend them without hitting a pot hole or something like that. A steep ramp and turning on the highway can bend them. A couple of guys on here have tried the street version on their trucks and had trouble with them also.
· Content Under Pressure
I would be very careful since they were not made for street use. Depending on how the roads are in you're area, just make sure you don't hit pot holes. You will be taking a risk in my opinion but you never know.
Cracked mine going into my driveway now they only go
On at the track I had rich bogart make me a 17 by 7 and I use that on the street in the front no problems over a year like that if not more
· Worlds Fastest Street HD Truck
The rears you can probably get away with since the tire has so much cushion and flex in the sidewall and the azz end is lighter and not handling as much turning loads, but the front no way. The street versions of bogarts crack, the race versions definitely will fail.
are the fronts on your truck right now bogarts? at Vinnies guys were saying the fronts were centerlines that matched close to the rear bogarts.
Reactions: Ct.TOPGUN
Mofos don't know what there talking about lol. Bogarts 17x7 made by rich bogart the center cap is a bogart center cap lol not a center line. Adams truck the sonic blue is a bogart in the rear and a centerline in the front.
Car Vehicle Pickup truck Automotive fog light Truck
· Administrator
I was the "MoFo" that thought the fronts of Redrum's truck were Centerline Split Spoke with Bogart caps. I thought the street Bogarts that Joey had made had failed. Perhaps this is an option after all.
lol, I assumed it was bogarts all around because they looked like a good match front and rear.
Hahahahaha ya Jimmy bo. 17x7 there still pretty heavy tho. As is Adams center lines
My buddy and I used to drive with them on the street all the time. The only ones that cracked were the fronts on my buddy's lightning. Prolly due to speeding over RR tracks and hitting speed bumps a bit too hard. We would just weld up cracks and continue to drive with them. Did it for a few years.
Discussion Starter · #12 ·
My buddy and I used to drive with them on the street all the time. The only ones that cracked were the fronts on my buddy's lightning. Prolly due to speeding over RR tracks and hitting speed bumps a bit too hard. We would just weld up cracks and continue to drive with them. Did it for a few years.[/QUOTE
Back are good the front one are the one that could crack or bent.. What tire where u guys running up front??
1 - 12 of 12 Posts
