1 - 10 of 10 Posts
I have the blower out replacing with another and was wondering while I have it out what can I remove to clean up the engine bay without causing any problems? i.e. vacuum lines from emision sensors, sensors them selfs, egr delete? Also the easiest way for an oil seperator. thx in advance.
ken
Florida>Texas
egr and pcv delete..and clean the intercooler while the blower is off
you can remove all the EGR stufff but unless you have a custom tune that turns them off...yoiu will toss codes and SES light
Bad Mother F'R
EGR Delete, PCV Delete, Ziptie Heater Hoses Back UNDER the firewall, delete the two hard I/C lines on the side of S/C, rerun boost vac lines.... there is ALOT you can do in there to clean it up....
Bad Mother F'R
Forgive the nastiness... Had surgery a couple weeks ago, its been raining and the truck hasnt been cleaned.... BUT, even through the dirt, you can get the picture. Still got some work to do, but Ive gotten rid of ALOT....
Bad Mother F'R
Thanks man!
Bad Mother F'R
Shouldnt suffer drivability, and as for the hole in the lower intake, the elbo that comes off and up to the passanger side can just be plugged with a vacuum cap. Thats what I did on mine. Then just shove it back behind the engine and ziptie it secure.
reroute the wiring to somewhere else in the cab
piece of cake
1 - 10 of 10 Posts
