Can this thing be "Rooted" like a phone to be able to install "other"apps not found in the app store?
It's just Android, so I cannot imagine it couldn't be 'rooted'...I can't remember if s|ck 'rooted' his Joying or not but I do know he updated it to Android 6 (Marshmallow).Can this thing be "Rooted" like a phone to be able to install "other"apps not found in the app store?
So I'm starting the install and the metra kit is no help at all and I suck at fabrication. You guys have any tips on getting the bezel to fit right? I'm thinking I'll trim the top and bottom of the bezel (unfortunately) with the dremel, and would atleast slide flush. The other issue is the 5mm gap on left and right side.
Doesnt this unit mount behind the face of the center console???.
It fits great. Same thing except I also trimmed the bottom which wasn't needed. I mistakenly was fitting the deck with the bezel out, but when installed it doesn't need the full opening because of the curved edge. Oh well it still looks great. Even with the gap its hardly noticeable. Will check in the daylight to see how noticeable it is.I only had to cut the top portion of the bezel with a Dremel. I cut a little at a time until it finally fit over the radio and snapped into place.
I ended up cutting the metra trim pieces quite a bit. Used some black double sided tape to secure them to the radio to fill the gaps on the sides of the radio.
I'm a bit suspicious of that too. Just like your phone how it starts slowing down. As long as it doesn't get loaded up with apps and kept clean, I can't see why it would drop off.Yeah, I'm hesitant because of all the reviews I've seen as well. A bunch of folks are saying they worked great... for a month or two.
Works fine for me.I've read a lot of reviews saying the memory or lack thereof is a real kicker. I use the Waze app a lot and apparently that's a no go with this radio. I'm leaning more towards the AppRadio 4 from Pioneer
https://www.amazon.com/Pioneer-SPH-...TF8&qid=1502647933&sr=1-1&keywords=appradio+4
or the 7" Corehan Android Radio
https://www.amazon.com/dp/B01MZYKCFH/_encoding=UTF8?coliid=I1783SBBOXV7I3&colid=1NA0Q39GCN5DD
zzzap i just put the sph-da120 in my l and have it in my f250 and love it fixing to build a 1 sub downfire box like mmcustom works built and be done with it
The Waze app does? how do you like everything else about it? Any problem using multiple apps?Works fine for me.
It's quad core so doesn't have problems multi-tasking. I am having problems getting a gps signal. And using cell data to connect even though the bt is working.The Waze app does? how do you like everything else about it? Any problem using multiple apps?
