1 - 3 of 3 Posts
anyone know the size of belt to use with a 10lb lower and stock idlers and stock upper? and where to get it thanks guys I tried checking the belt chart thread but there is no part #'s listed
The length you need is 70.5 im not sure about the part number but if you call Mark at LFP he can hook you up with a good Gates Green Stripe belt. :bigtu
I don't use the chart. I always want the shortest belt that I can get on. So I pull up in front of NAPA. Grab a few belts I know are close. And try them on. They don't mind, as I am buying one. Takes minutes and you are assured of proper fit.
1 - 3 of 3 Posts
