61 - 80 of 82 Posts
Discussion Starter #62
IIRC the TPS "bolts" are actually under "screws" category, IIRC they're an M5 and I believe the smallest ARP does is an M6.
Yeah I just went to the local hardware store and got stainless Allen screws for the tps
Sent from my SM-G965U using Tapatalk
Hey guys I am searching for ARP hardware for the timing chain guides and tensioners. Does anyone happen to know the ARP part numbers for these for a 2V. I have the cam gear bolts already.
Thanks
If anybody needs and or wants the arp midplate stud and nut set I have them and dont need them.
$68 shipped + fees
Panty Dropper
Bump to an old thread. Looks like the part number for the 2.6 studs is out of date, and searching through summit, they no longer make one in 4” with the same specs. Anyone ran into the issue recently with a new part number by chance?
2003 Ford Lightning
Hey everyone. I know I'm a bit late to this post, but I saw that someone was putting a word or spreadsheet together with all of this info on it. I was wondering if I could get a copy of that emailed to me. I would greatly appreciate it. Thank you and hope you all are doing well.
Location Quantity Sku#
Fenders 6 770-1016
Ground 770-1016
Dipsticks 2 770-1016
Alternator 3 770-1016
Fuel Rails 4 770-1016
Water Pump Pulley 4 771-1017
Idler Pulley 5 771-1001
Oil Filter Adapter 4 771-1004
Starter 3 771-1004
Lower Intake 10 771-1004
Throttle Body 2 770-1017
Cam Sensor 1 770-1017
Starter Sol. 2 770-1017
IAC 2 770-1017
Crank Sensor 1 770-1017
Header 16 771-1003
Tensioners 6 771-1003
Idler Bridge 1 771-1003
Midplate 4 772-1005
Dipstick 1 770-1002
Alternator 2 771-1006
PS Pump 3 771-1010
Flexplate cover 2 672-1001
Water pump tube 2 672-1001
Motor Mount 6 672-1001
Starter Sol. 2 401-8323
Throttle Body Bracket 2 400-8380
Thermostat Housing 2 771-1014
Idler Bridge 3 400-8311
Starter ground 1 400-8311
Starter 3 771-1004
Flywheel 8 254-2801
Plenum to supercharger long bolt 1 770-1012
Plenum to supercharger short bolts 5 770-1003
Midplate to lower in the rear 4 772-1005
Upper intake to lower 4 772-1007
Supercharger (through upper intake) to lower intake studs 4 ARP AM4.600-1LB these are black
Supercharger (through upper intake) to lower intake stud nuts 4 ARP 200-8683
Supercharger (through upper intake) to lower bolts I couldn't find ARP equivalent.
Supercharger snout bolts (I bought the Ebay kit)
Coil over plugs I couldn't find ARP M5x0.8x30 McMaster-Carr 92290A254
This summer I will be doing another engine and hope to verify and reverify these lists.
IF ANYBODY HAS AN ARP FOR THINGS I'M MISSING LMK.
Thanks
2003 Ford Lightning
ARP Bolts
PartQuantityPart #CostStore/Site Total Cost
Fender6770-1016$14.99 Pack of 5Summit Racing $ 59.96
Ground1770-1016
Dipstick2770-1016
Alternator3770-1016
Fuel Rails4770-1016
Idler Pulley5771-1001$16.99 Pack of 5Summit Racing $ 16.99
Oil Filter Adapter4771-1004$24.99 Pack of 5Summit Racing $ 99.96
Starter3771-1004
Lower Intake10771-1004
Water Pump Pulley4771-1017$16.99 Pack of 5Summit Racing $ 16.99
Throttle Body2770-1017$15.99 Pack of 5Summit Racing $ 31.98
Cam Sensor1770-1017
Starter Solenoid2770-1017
IAC2770-1017
Crank Sensor1770-1017
Header16771-1003$18.99 Pack of 5Summit Racing $ 94.95
Tensioners6771-1003
Idler Bridge1771-1003
Mid-plate4772-1005$26.99 Pack of 5Summit Racing $ 26.99
Dipstick1770-1002$16.99 Pack of 5Summit Racing $ 16.99
Alternator2771-1006$24.99 Pack of 5Summit Racing $ 24.99
Power Steering Pump3771-1010$26.99 Pack of 5Summit Racing $ 26.99
Flex-plate Cover2672-1001$12.99 Pack of 5Summit Racing $ 25.98
Water Pump Tube2672-1001
Motor Mounts6672-1001
Starter Solenoid2401-8323$6.99 Pack of 2Summit Racing $ 6.99
Throttle Body Bracket2400-8380$11.99 Pack of 2Summit Racing $ 11.99
Thermostat Housing2771-1014$28.99 Pack of 5Summit Racing $ 28.99
Idler Bridge3400-8311$11.99 Pack of 2Summit Racing $ 23.98
Starter Ground1400-8311
Flywheel8254-2801$38.99 Kit (8)Summit Racing $ 38.99
$ 553.71
Is there anything that is missing? If so please let me know.
I’m possibly looking to get rid of some of my ARP bolts packs is anybody interested if I am? Just wondering!?
Message me part numbers and price please
Thanks for all the good info! I though that putting all the dimensions in might be worthwhile and I added a few items out of the thread. Didn't understand the aftermarket stud and bolt posts, so I didn't include them here
PartQuantityPart #DimensionsCostStore/SiteTotal Cost
Fender
6​
770-1016M6x1.00x12mm$14.99 Pack of 5Summit Racing
$59.96​
Ground
1​
Dipstick
2​
Alternator
3​
Fuel Rails
4​
Idler Pulley
5​
771-1001M8x1.25x20mm$16.99 Pack of 5Summit Racing
$16.99​
Oil Filter Adapter
4​
771-1004M8x1.25x35mm$24.99 Pack of 5Summit Racing
$99.96​
Starter
3​
Lower Intake
10​
Water Pump Pulley
4​
771-1017M6x1.00x16mm$16.99 Pack of 5Summit Racing
$16.99​
Throttle Body
2​
770-1017M6x1.00x16mm$15.99 Pack of 5Summit Racing
$31.98​
Cam Sensor
1​
Starter Solenoid
2​
IAC (Eaton)
2​
770-1003M6x1.00x30mm
IAC (KB)
2​
Crank Sensor
1​
Header
16​
771-1003M8x1.25x30mm$18.99 Pack of 5Summit Racing
$94.95​
Tensioners
6​
Idler Bridge
1​
Mid-plate
4​
772-1005M10x1.50x40mm$26.99 Pack of 5Summit Racing
$26.99​
Dipstick
1​
770-1002M6x1.00x25mm$16.99 Pack of 5Summit Racing
$16.99​
Alternator
2​
771-1006M6x1.00x45mm$24.99 Pack of 5Summit Racing
$24.99​
Power Steering Pump
3​
771-1010M8x1.25x65mm$26.99 Pack of 5Summit Racing
$26.99​
Flex-plate Cover
2​
672-1001M10x1.50x20mm$12.99 Pack of 5Summit Racing
$25.98​
Water Pump Tube
2​
Motor Mounts
6​
Starter Solenoid (Nut)
2​
401-83235/16"x18$6.99 Pack of 2Summit Racing
$6.99​
Throttle Body Bracket (Nut)
2​
400-8380M6x1.00$11.99 Pack of 2Summit Racing
$11.99​
Thermostat Housing
2​
771-1014M8x1.25x90mm$28.99 Pack of 5Summit Racing
$28.99​
Idler Bridge (Nut)
3​
400-8311M8x1.25$11.99 Pack of 2Summit Racing
$23.98​
Starter Ground (Nut)
1​
400-8311M8x1.25
Flexplate/Flywheel
8​
254-2801M10x1.00x1.0"$38.99 Kit (8)Summit Racing
$38.99​
1​
770-1012M6x1.00x75mm
5​
4​
4​
772-1007M10x1.50x50mm
4​
AM4.600-1LBM10x1.25/1.50x4.6"
Supercharger (through upper intake) to lower intake stud nuts (Locking)
4​
200-8683M10x1.25
COPS? (McMaster is Stainless)
8​
N603257-S100 Ford/McMaster-Carr 92290A254M5x0.8x30
Exhaust Manifold/Header Bolts
16​
761-1003 M8x1.25x30mm
TQ Convertor to flexplate
4​
300-83323/8"x24
Timing Cover
13​
771-1006M8x1.25x45mm
Bottom two corner timing cover bolts
2​
772-1007M10x1.5x50mm
4V Idler Pully
1​
772-1008M10x1.5x60mm
Tranny to Engine Block
6​
Depends on length?M10x1.5
TPS (McMaster is Stainless)
2​
Harmonic Balancer Bolt 4.6/5.4 Non CJ/GT500
1​
156-2501M12x1.50x1.8"
ARP M6 Stainless WashersN/A400-8711M6x.890x4.2mm
ARP M10 Stainless WashersN/A400-8532M10x.865x4.1mm
Fender
6​
$59.96​
Ground
1​
Dipstick
2​
Alternator
3​
Fuel Rails
4​
Idler Pulley
5​
$16.99​
Oil Filter Adapter
4​
$99.96​
Starter
3​
Lower Intake
10​
Water Pump Pulley
4​
$16.99​
Throttle Body
2​
$31.98​
Cam Sensor
1​
Starter Solenoid
2​
IAC (Eaton)
2​
IAC (KB)
2​
Crank Sensor
1​
Header
16​
$94.95​
Tensioners
6​
Idler Bridge
1​
Mid-plate
4​
$26.99​
Dipstick
1​
$16.99​
Alternator
2​
$24.99​
Power Steering Pump
3​
$26.99​
Flex-plate Cover
2​
$25.98​
Water Pump Tube
2​
Motor Mounts
6​
2​
$6.99​
2​
$11.99​
Thermostat Housing
2​
$28.99​
Idler Bridge (Nut)
3​
$23.98​
1​
400-8311M8x1.25
Flexplate/Flywheel
8​
$38.99​
1​
5​
4​
4​
4​
4​
200-8683M10x1.25
8​
16​
761-1003M8x1.25x30mm
4​
300-83323/8"x24
Timing Cover
13​
2​
4V Idler Pully
1​
6​
2​
1​
Can you put this as a pdf file for people to download and keep? That wld be awesome to have on had seperate from this thread. When its finalized of course. Thanks for doin this in a better format.👍👍👍👍👍👍👍
61 - 80 of 82 Posts
