1 - 8 of 8 Posts
· Premium Member
I have two areo force gauges for several years i was using the setting buttons to change to battery volt reading, Now the two red lights at the top are on any help would be appreciated Thanks
· Worlds Fastest Street HD Truck
aren't those annunciator lights? you can set values that if one is exceeded greater than or less than a set value, or a combination of two things, it'll illuminate an annunciator light.
· Premium Member
THANKS GOT THEM CLEARED OUT NOW
Thanks, Have them cleared out now no Red lights.[smilie=3g
· Premium Member
AREO FORCE GOOD GAUGES TO HAVE
What data rate do you have them both set at?
I Have one set on motor oil temp, and transmission temp.
and the other IAT and oil pressure, The data rate is unimportant to me i am more concerned about Temp, Motor Transmission etc, Tom[smilie=3g:rockon_ford
· Jeffv333
and the other IAT and oil pressure, The data rate is unimportant to me i am more concerned about Temp, Motor Transmission etc, Tom[smilie=3g:rockon_ford[/quote]
It was a question for me, I am just wondering. I want to compare your data rate with mine. I sometimes have issues with my gauges. I think they're way pricy according to all the complaints I hear about.
· JDM Built/KB 3.2
Mastertvtech does no longer deal with these gauges. He works close to me and I talked to him over the phone about them.
1 - 8 of 8 Posts
