Has anyone ever tried to to use this 4 link setup before? Says it's bolt in for our setup just needs and added Panhard bar.
Thoughts?
Thoughts?
Use what?Has anyone ever tried to to use this 4 link setup before? Says it's bolt in for our setup just needs and added Panhard bar.
Thoughts?
Thanks for that. Any recommendations on 4 link setup parts?Few guys running modified versions. Back in the day scottselle made kits using components from the kp kit. The guys who ran the off the shelf kit had issues with the axle side brackets, and bushings supposedly had issues failing really early as well.
that parallel 4 bar setup is more for the air bag groups, not really intended for drag racingHas anyone ever tried to to use this 4 link setup before? Says it's bolt in for our setup just needs and added Panhard bar.
Thoughts?
Custom built.
Other than that his name escapes me but there is a Harley truck with a similar setup, he used an off the shelf link kit but it's been basically totally 're done.
I'm hungover and barely awake, but what's your intention? Drag race, road, or just better street manners?
Mdan575, I was just going to drop your name and KC components as one of the guys using a 4-link. I considered going the same route you did but after I retire the truck from work duty because of the constant weight that I carry. 600-700lbs 24/7. Its alot of stress on all those joints. Plus I would have to figure out a way to either use the bags I have (load helpers) or a new set. This setup also uses shocks not just airbags. Which IIRC is what Mdan used (coilovers).:smt023
