Anybody knowledgeable on SCT Advantage III tuning software need some help
225 Views 9 Replies 3 Participants Last post by  slow94
I have some trans tuning questions I need help with if anybody had the knowledge
1 - 10 of 10 Posts
What is your particular question?
I sometimes have a slight bog after my 1-2 shift. Datalogs show timing dropping to -12 and tourqe reduction is set at .500
Does TR pull timing, and if it pulls enough to reduce tourqe by 50% can it cause a slight bog down. Bogs it like 50% of the time.
It only appeared after I lowered the shift pressure a little
It's a built 4r70 in a swapped 4x4 running a tuned NA ecm
Turn Tq reduction off and do the J mod to the trans.
Log spark source to see what is pulling the timing.
[email protected]
I beleive I have the j mod already darrin burch just built it for me. I did log it and I can see a big hole where it pulls timing and the rpms fall flat. It's not as bad when trans is cold
Here's a rpm/timing shit of a funky shift I can see the big hole for timing drop for TQR
Slope Font Parallel Rectangle Pattern
See less See more
Here's a shift withcthe trans still mildy cool its not as pronounced
See less See more
Most likely torque modulation. Need to turn that crap off.
Was under the assumption it helps the intermediate clutches love longer
Probably does.. I got a built trans so I want all the power all the time.
1 - 10 of 10 Posts
