I have an Aeroforce Gauge I have the boost sensor I know I need to get other parts to complete the install, but cant find what else is needed can someone help me?
Dont I need to buy a vacuum hose?Just the bar map sensor, and wire her up. Comes with instructions.
Harley's don't have factory boost gauges.I just put mine in too the vacuum line where my stock boost gauge hooked up at
And if you still want to use your stock boost gauge you can buy a little t and small piece of vacuum
No, I haven't wired anything except the gaugeOk, when I get the chance I'll post a pic of where you want the gauge to tap in to measure boost. If the set up didn't come with vac hoses, then you will need to buy a vac hose about 5ft should be more than enough I think.
Have you wired everything already? Or do you need to know where to mount sensor etc.?
