1 - 9 of 9 Posts
i'm about to remove this eniter system. i'm still filling up the oil seperator, and i'm sure some is getting into the blower. i looked at the crankcase on both sides, and it looks like there is 2 spots to put breathers on. one for the oil cap, and one for the pcv. on the passenger side, there is another outlet that i'm going to have to put a breather on. can someone direct me to a website that i could get some nice breathers for all three, that are a direct fit. i don't want to have to install 3' of rubber tubeing to get these things to work.
thanks
chiz
Just some food for thought...
*not* having a vaccume on the cranckcase will increase blowby and therefor reduce ring seat/power. You'll most likely not notice it on a stock truck. But on one pushing a lot of boost you just might.
The other side effect is increased oil changes would be advisable as more contaminates will be getting past and down into the mix.
Rich
George\/
do you have your oil seperator on correctly?? i know with mine it has an in and an out with a little arrow pointing the way. the arrow should be pointing toward the blower and you will have very little oil in it. i had mine on backwards and it filled up instantly
and i deleated the tube on the drivers side and put in a breather
yes, i have it pointed in the right direction.
wydo, i'm not really concerened about any of that at the time, mainly just the oil getting in. when i get everything done i'll test it out and if it is effecting anything í'll switch back, no biggie.
i've found a kit for the egr, now i need to find out where to get the breathers. i'd like all 3 to match. i found one at psp for the oil cap, but i'm not sure if they sell the other type.
sal, do you have these? if your reading......
mike, i actually have that exact one plus a cobra pcv. unfortuantely its doing its job too well and i'm tired of worrying about getting oil in it. sucks to do all that work pulling the s/c and cleaning the intercooler for it to get durty again. [smilie=popcorn.gif]
i found all the stuff i need, i'm just waiting on a relply on the blockoff kit. i'll do a write up on how i did it, materials needed, pictures, etc.
thanks for the help guys
Discussion Starter · #9 ·
thanks for the reply usaf_eagle. i just sent you an email.
guys i ordered the ones JLP has for the crankcase. i'm trying to get a hold of someone at PSP to get the oilcap one now.
-chiz
1 - 9 of 9 Posts
