Solenoids re-installed
All Wired
System is once again funtional
(no nozzle hook up "YET")
Bottle Bracket mounted (needs 2 more holes drilled and inserts installed in bed)
Both Bottles Installed
TP-1 re-hooked up and set (Throttle Position Switch)
Maximiser re-hooked up and set
A very productive day indeed
WHAT AN AWESOME SET UP,
[smilie=bow.gif] @ DENNY, cant wait to start spraying again :smt101
THANKS PAL (and Thank You Trev)
THE LARGER AND HIGHER RES PICS ARE HERE
http://www.robs02lightning.com/gallery/thumbnails.php?album=8
Took it out for a nice ride this morning before the wrenching started
WOOOOOOOOOOOOOO HOOOOOOOOOOOO
CAN YOU SAY BOOST....................
This thing has NO MORE tapping when started on 20 degree mornings
Idles better than it EVER did
Is quite as schitt even with the Headers and Hi Flow Cats (even on the parkway @ 80)
The Magnum is frigging unbelivable, (screams like a Virgin in a Max Security Prison Shower)
AND THE POWER DIFF IS NIGHT AND DAY, wooooo hoooooooooo
For a whine Lover like me, between the Factory Tech TD Converter whining away,
and the Magnum Powers screaming away, this frigging thing is UTOPIA
WOO HOO........................
