Trickflow heads and comp cams. I have aftermarket cats on now. When you say it felt stronger. Was that after the exhaust change with new injectors?
After putting two cats back in (from none and obx lt's and spintech's w/ dr gas x)
At wot at the high end it goes to 12.25 a/f ratio
my WOT and idle A/F after moving the truck from 0-500 elevation to 1500-3000 elevation changed a little. Right now it sits at about 14.8/15.1 when idling and 10.8-11.1 @ WOT. Originally the tune was at 14.7/11.3 +/- .1 A/F (before moving it cross country).
12.25 as i understand it near WOT would be OK, but on the lean side of WOT for S/C application?
For awhile I had issue with the tip in or going from little to no load to light or medium load, it was a little too lean too long in that section. This resulted in some stumbling behavior when attempting to go from say cruising at 60 to very mildly accelerating to 80. The truck would stumble first every time. This has been fixed in a later retune.
Pulley to compliment the added airflow from heads and full exhaust + A better tune (more aggressive timing ramp) would've fixed your grunt problem without forking over money to redo the exhaust and adding cats back in. TFs like timing.
In hindsight I do realize I need to get back to the tuner. When all of the work on my truck was done, that final tune came somewhere around November 2009. I think there were two trucks on the the road in North America with TF heads at the time and mine was one of them. This of course could be wrong, but I was still among the first. I was a guinea pig.
30000 miles later I can tell you that the TF's probably want more timing, and if you're running TF's and cams and have no exhaust back pressure and also find yourself running the stock super charger, its gonna be a pig out of the hole.
I'll probably get it re-tuned after getting the XTi back on the road
