This is a discussion I'd like to see more of, as well as really nicely done "How To".
I'm not too considered with gains at the strip, as much as enhanced driveability on the street. Tighter splits and a more modern feel. It would have been nice if the 6r80 would drop our revs on the freeway without changing the final drive, but that's not too bad. It could also be cool having different shift programs with the Quick 6.
Look at the torque curve of the lightning.
I'm not sure the splits are an issue
Someone's posted most of a how-to on Facebook.
Here is a visual of the differences between the transmission
This is a 6r80 with stock gears and tires. Its showing speed at 5800 rpm shift points, and the rpm the engine will drop to in the next gear.
First gear is very aggressive
With this setup in overdrive you are at 2300 rpm at 75 mph
Here is the 6r80 with 3.08s
You are at 1900 rpm at 75mph
From the older 6 speed threads, both cody and kyle complained about lugging these motors with the tall overdrive of the viper 6 speed. The viper T56 with stock 3.73s puts the engine at 1675 at 75mph
Here is the stock 4r100 and stock gears
2350 rpm is 75mph
