1 - 10 of 10 Posts
Looking to sell my 2003 Turbo Ford Lightning
Due to life events I’m moving on from this truck. It’s a freaking blast to drive, not to mention it’s not even on a aggressive tune. The truck sounds ridiculous, very loopy
If you’re serious about purchasing the truck, we can set up a date and time and I can FaceTime you and I will show you every inch of the truck.
Was once in Ford Trucking Magazine, With a nice little article. I have the magazine along with the article that will come with the truck.
I have the SVT certificate for it as well.
88,*** Miles
VIN # 2FTRF07373CA51174
Here are some details
Built 5.4
8.8:1 compression
Double keyed crank shaft
Oliver Rods
Manley Pistons
Clevite main Bearings
Arp main studs
Arp head studs
Total seal Rings
Patriot Performance Ported stage 3 PI Heads
Canton 7Qt oil pan
Injector Dynamics 1000CC
Crane Cams
Magna Fuel 750 Fuel pump
10An Fuel line
JLP Fuel rails
Sumped Stock Fuel tank with filter
Deep Sump trans pan
PI 2800 Converter
Punisher Shift kit
Widened stock rims 2"
345 Mickey Thompson ET street radial tires
76mm Precision Turbo
Custom made Intake hat
Turbo smart waste gate
Greddy boost controller
Greddy blow off valve
4" stainless exhaust
Truck has been tuned by Adam at PopsRacing
Final tune Needs to be completed (need a dyno) won't hook on street.
Truck hasn't been on the Rollers
Drivability is Great
Garage kept for most of its life.
Was in Ford trucking magazine
Looking to sell and or Trade
17850
4104749174 Call or Text
Located in southern Maryland
Let me know what you have for trade, really interested in form 4 firearms..
And some on this site say my new Mag-Hytec transmission pan will be too low. Look at that exhaust pipe, what is it, like two inches ground clearance? WOW!
What transmission pan is that, btw? I took some measurements and I will have a bit over 7 inches clearance once the M-H is installed. Just waiting on a cat in Tulsa to get his Punisher out and sell it to me. If he doesn't hurry, I'll just go ahead and buy one from JJ.
1 - 10 of 10 Posts
