Has anybody use ProMaxx head and do they like the results they get from them. Gen 2 lightning
You would think that me and my shop would have had at least one failure considering how many sets of these heads we have installed over the years. And I'm not talking just Lightnings or Harleys here, I do quite a bit of Mustang work as well and alot of 4.6 2V TF head installs and even in that community where those heads are used at least 10:1 over Lightnings the failure rate is pretty low.I personally know 5 people with tf failures due to bad valves or guides. Me included.
I don't know of a single follower problem. I know of 3 bad guides and 2 valves to that had the head separate.
My cams are custom spec's for my truck and heads.
I’mI'm not saying every head is a time bomb. But if you're already spending good money, buy bare castings and have good parts installed.
My springs and guides, along with having the head resurfaced was $1100. Add in a set of valves and that's cheap piece of mind honestly.
Thanks for the input
maybe you should have gone the proven route thru Woodbine MotorSportsI'm not saying every head is a time bomb. But if you're already spending good money, buy bare castings and have good parts installed.
they look like cheap copies of stock headsHas anybody use ProMaxx head and do they like the results they get from them. Gen 2 lightning
If you're in a rush to put together a motor, I'd suggest dropping the word best from your search.Thanks for the input
Only reason I was asking is because I have enough funds to do trickflow and they won’t be available till February the only reason i looked into promaxx look good he said they’re using Pac springs and ferrea valve I’ve already ordered them two weeks ago, but like to see how they perform, I can always sell them later once I get enough money for trickflow. I know or the best head you can buy for 5.4
What camshaft do think have the best camshaft where to buy
I hate them heads so much. They cost me so much pain and agony and money. Yes I agree with Dusten. Buy bare TF heads and have a reputable head shop build them with good parts and save you a lot of time and stress in the future. Cry once pay once. Dont do what I did on my third , forth and fifth built engine. Second built engine was a failure to “well known” vendor that people nut swing on. But that’s another storyFuck I had a long post and accidentally reloaded the page
@BlowerWhore and @Leeproctor83 are both personal friends. I'll let them describe the failure.
Scott cedergreen who's passed away had a valve head come off. 200 miles after his new motor was running. Tf admitted a part failure and warrantied it.
My heads lasted almost 10,000 miles. Cam specs are 237/239 .556 lift and 114 lsa. Spec'd by Todd Warren for my heads and engine.
Shitty powdered metal valve guide disintegrated and bent a valve.
JJ my TF heads failed even using correctly specd cams you sold me. Not saying every TF head is affected but enough for me to not buy them heads and use them out of the box. You must be one lucky SOB to have zero failuresYou would think that me and my shop would have had at least one failure considering how many sets of these heads we have installed over the years. And I'm not talking just Lightnings or Harleys here, I do quite a bit of Mustang work as well and alot of 4.6 2V TF head installs and even in that community where those heads are used at least 10:1 over Lightnings the failure rate is pretty low.
Over the years I have seen a few threads or posts about a particular failure and each one of those instances were due to improper installation procedures or using the wrong cam.
Personally I would like to know more about these failures and the circumstances behind the failure, if that is even possible.
JJ
Scott cedergreen had a valve come apartHere is what I dont understand. You are willing to hate on Trickflow because of your bad experience but I dont think you have ever once mentioned who your failed built motor was purchased from. Why not? I mean if you are making statements about your experience with TF why not make the same statement and mention the built motor supplier?
It reminds me of another person I dealt with about two years ago that contacted me about a spun rod bearing in his new build that was done by another shop. I spent alot of time on the phone trying to help diagnose the issue and help him figure out a solution and when he told me the story I was amazed he wouldnt say anything about it publicly, especially since he swung so hard for this company on Facebook and here. After spending about 35K with them they told him to pound sand. The mentality of this has always amazed me... Anyway..
Trickflow failures.... Lets discuss... Actually let me toss out my unpopular to those who have had failures opinion...
I will preface this by saying yes, Trickflow has had some failures that were a direct result of product failure. However the three failures I have seen in person were all due to improper installation procedures for the camshaft.
You see most people do not have the tool that compresses the valve spring to install the follower after the cam has been installed, so they install the followers, find a roughly "neutral" cam position and lay the cam in place, then tighten down the cam caps, hopefully torquing them to spec and that is the absolute worst way to install a cam in a cylinder head. The proper way is to have the lifters in place, install the cam with no followers in place, torque the cam caps and make sure the cams spins freely in the head before you use the tool to compress the valve (with the piston down) to install the intake and exhaust followers. (cam lube everywhere of course) Doing it the wrong way does not ensure proper cam cap torque and can "bind" the valve train which will result in kicked off followers, valve/piston damage etc... All easily blamed on Trickflow of course.
Most likely the above paragraph should explain why I have had Zero failures of any Trickflow head in house.
[email protected]
I'm not blaming the end user for all Trickflow failures. I even stated that Trickflow has had some failures due to the product itself. I'm simply stating that the ones that I have seen in person were due to improper installation and I'm also posting that incorrect installation of the cams and followers is a very common practice used not only by DIY's but I've even known other shops that do it to save time.Scott cedergreen had a valve come apart
I had a valve guide fail and installed my cams as you've stated and degreed them
Kenny proctor had a valve head come off
I don't remember Mike's failure.
Again, I'm sure the heads for the most part are fine. But blaming the end user is a cop out.
