1 - 14 of 14 Posts
What’s the best approach to putting a 2001 Lightning back to stock ride height? I see drop spindles in the front & appears shackles in the rear. Thanks
11 second street truck
Replace the parts off the truck with oem. You can likely find someone willing to trade plus cash for your parte
Dude
Pick a part? Junk yard
I know the upper and lower control arms from a standard F-150 fit the Lightning. The lowers are just missing the steering stops, since the L has such fat ass front tires. Lightning's are one inch lower than standard F-150s, but is that due to the fat low profile tries, or a different spindle?
Member Senior
It's lower because of the springs. The spindles are the same as any F150.
Sent from my G8441 using Tapatalk
Yeah. I got to thinkin about it after I turned my computer off for the day, and that was my final thought on the subject. Lower springs. I suppose I read it here a long long time ago. Or NLOC. Don't recall.
Thanks for helping the OP understand.
Member Senior
Let me check what I have in the stash.
I found a set of spindles but they were outside and pretty rusty. I think you would be better off getting them in a wrecking yard. Found some stock front springs too if you end up needing some.
Discussion Starter #12
I would be interested in the springs! Fronts I assume? Year?
1 - 14 of 14 Posts
