Hey what’s up bro Trick actually told me he designed the 12 row around the JC mid plate and needs no modifications. We will see though!I know you have the JC plate. Will you have to modify it for the 12row?
I will be storing the second core for when it’s needed. I just hate to be swapping from the stock whipple mid plate and stock IC when I have a leaking IC. My truck for some odd reason loves to eat ICs…How are you going to utilize 2 of these on one truck? Sorry if I'm totally missing something.
Are you using reg tap water in it or something that is corroding it from the inside.I will be storing the second core for when it’s needed. I just hate to be swapping from the stock whipple mid plate and stock IC when I have a leaking IC. My truck for some odd reason loves to eat ICs…
I have to bro! I hate waiting for parts when you have a failure!You big ballin bro. Storing the other one just incase 😂 good preventative measure though.
You know your knifes! Love my Microtechs 🍻Beautiful!! That Microtech too 👍🏻🔥
I was running regular tap water/ice water through it in the summer and warmer months. For winter, I swap to Prestone 50/50. I was recommended by Trick to ALWAYS run coolant though. Will be doing so for the foreseeable future.Are you using reg tap water in it or something that is corroding it from the inside.
They were splitting. If he had the flow backwards he could have easily built back pressure and split them.Are you using reg tap water in it or something that is corroding it from the inside.
Well, that's weird, I've apparently had mine backwards for years too then. The Tim White pre-made hoses route it opposite. Wonder if I should go through the hassle of switching it now, i've never had any problems, but the hoses only fit one way. Comes in on passenger's side, and out drivers, which appears to be wrong. HmmmmAnother side note I'd like to mention is... According to Trick, you must feed the water IN line coming from your heat exchanger to the bigger tank on the core. The smaller tank side is the the return OUT line that goes back to reservoir. I did have that reversed. Maybe an issue? Will now see. But for the record I was never told about this by Trick or anyone else when I purchased my first core years ago.
That's because routing doesn't matter on the stock setup.Well, that's weird, I've apparently had mine backwards for years too then. The Tim White pre-made hoses route it opposite. Wonder if I should go through the hassle of switching it now, i've never had any problems, but the hoses only fit one way. Comes in on passenger's side, and out drivers, which appears to be wrong. Hmmmm
I didn't think it did on either setup, but I know now! Learn something new every day lol. I plan on making a video making others aware, and i'll probably talk to Tim, just so he knows too. Ended up going and switching the hoses around, bothered me knowing I had it on there wrong, even though i've never noticed any issues with it that way.That's because routing doesn't matter on the stock setup.
I’ve always ran distilled water and water wetter in the summer and just add some antifreeze in the “winter” I live in south Ga so it doesn’t take much lol. I’m still running the stock IC. I’ve never heard of flow direction thing. Is it just a Trick IC thing and is it the same for stock the IC? I don’t think I can tell with the stock one if one side is bigger then the other.I was running regular tap water/ice water through it in the summer and warmer months. For winter, I swap to Prestone 50/50. I was recommended by Trick to ALWAYS run coolant though. Will be doing so for the foreseeable future.
Another side note I'd like to mention is... According to Trick, you must feed the water IN line coming from your heat exchanger to the bigger tank on the core. The smaller tank side is the the return OUT line that goes back to reservoir. I did have that reversed. Maybe an issue? Will now see. But for the record I was never told about this by Trick or anyone else when I purchased my first core years ago. View attachment 549404
It's a trick thing due to the shape of the core.I’ve always ran distilled water and water wetter in the summer and just add some antifreeze in the “winter” I live in south Ga so it doesn’t take much lol. I’m still running the stock IC. I’ve never heard of flow direction thing. Is it just a Trick IC thing and is it the same for stock the IC? I don’t think I can tell with the stock one if one side is bigger then the other.
Ok cool thanks. I was just out looking at my stock one like WTF. LolIt's a trick thing due to the shape of the core.
Exactly what Dusten said just beat me to it. That's why I mentioned in this post so people can be aware!!I didn't think it did on either setup, but I know now! Learn something new every day lol. I plan on making a video making others aware, and i'll probably talk to Tim, just so he knows too. Ended up going and switching the hoses around, bothered me knowing I had it on there wrong, even though i've never noticed any issues with it that way.
I've looked and no way of telling if one side is bigger than the other one stock Inter cooler. I recommend running the hoses how they are from factory on the stock IC.I’ve always ran distilled water and water wetter in the summer and just add some antifreeze in the “winter” I live in south Ga so it doesn’t take much lol. I’m still running the stock IC. I’ve never heard of flow direction thing. Is it just a Trick IC thing and is it the same for stock the IC? I don’t think I can tell with the stock one if one side is bigger then the other.
