1 - 12 of 12 Posts
Thinking about putting a 2 step
Stock trans with valve body
Will it hurt anything at like a
22-2500rpm launch
And what's a good one to go with
Na man ur good I run one good times
Stock block 11 second club
Seems like a mod for the sake of modding at your current state, just my $.02. You might want to try "flashing" the converter and doing some test & tuning to see if you can't dial in your launches. Most of the fastest Ls/HDs cut serious 60s without a two-step.
I've heard good things about the N2MB WOT Box. If you're going to run slicks at the track then I say go ahead. I'll be using one in the future.
Are their any benefits of a two step on a supercharged application? I thought that a two step allowed you to build boost before the launch? I am confused...
1 - 12 of 12 Posts
