1 - 11 of 11 Posts
· Mr. Crossfire
I need a 12v source from the transmission harness to trigger a relay to my trans cooler. Anyone know which sensor or wire I could use, I know its a long shot. FYI I have a TH400 so harness isn't being used folks.
· Worlds Fastest Street HD Truck
Why do you need it to be from the trans harness?
One of these would do exactly what ya need lol
· Mr. Crossfire
My trans cooler is mounted to the x-brace in the back of the truck. Need a 12v source to trigger the relay so when I start truck fan automatically come on. My trans harness is near my front bracket to my long bars.
Pretty simple: carefully tap your fuel pump positive wire. If it's going to a relay you will be fine. Be sure to use a good ground. Even when the pumps are not operating at full voltage you will have 12v at your relay with a chassis ground.
Enjoy!
· Mr. Crossfire
Enjoy!
Not being smart but is it smart to touch a line that powers the fuel pump? Wont that take away voltage from my pump (I have single pump).
1 - 11 of 11 Posts
