Asking 13,000 for truck and new trick flow (185 44c 150lb spring)heads and cams in brand new in box from Woodbine.
ISSUES with truck.
-The R heads on the truck need to be pulled and replaced with new trick flow heads
-The carbon radiator shield will not sit flat(I was just going to buy new one without sticker and trash carbon)
-The rear main seal needs to be replaced
66,000 miles
Engine
JLP shortblock
JLP r heads/stage 2 cams
JLP compr exhaust
kb 2.6 with powerflow plenum and JLP intake
Woodbine fuel system with fore hat and triple pumps
80# injectors
built transmission with circle d stall
tru trac rear end
suspension
drop spindles in front
JLP shackles and lowering leafs
JLP long bars
QA1 rear adjustable shocks with flip kit
killer chiller(heat exchanger deleted and transmission cooler mounted in its place)
stock grilles included. in order to put top grille in a new fascia will have to be ordered($100) and painted because clips were cut off to put billet grille in.
spare tire and winch removed
cruise control deleted
gauge cluster installed and pillar/handle reinstalled. I have and extra pillar and bracket. these are hard to find
ISSUES with truck.
66,000 miles
Engine
JLP shortblock
JLP compr exhaust
80# injectors
tru trac rear end
suspension
JLP long bars
