1 - 9 of 9 Posts
About 120,000 on the body, running when taken apart for dress up ARP chrome bolts, and powder coating, Repair company went out of business, and needs to be put back together, I'm not a mechanic.
2002 True Blue
Carriage Works Upper & Lower Grilles
New Factory Head & Tail Lights
RUSLOW rear Mount Battery Tray
0356 Harley Rear Battery mount wiring kit w/alternator
Tru-Trac Limited Slip 3:73
Fiberglass Leaf Springs
2 Spare Wheels with Nitto Drag Radials
QA1 Adjustable Shocks (Rear)
Bilstein Front Shocks
Hytech Rear end Cover
Carbon Fiber Drive Shaft
Bronco Busters Long Bars and Driveshaft loop
Dante Built Transmission
Deep trans pan with Magnetic plug
Circle D 3200 Stall Torque Converter
F250Trans Cooler
Upgraded Brake Rotors & Pads
Aeromotive Fuel System (Lines, Rails, Filter & Regulator)
Dual Aeromotive 340lph pumps on modified factory cap (2) 6 AN Feed, 1 6 AN Return)
Killer Chiller
JC Customs Ice Tank
Upgraded Inter Cooler Lines
Mezzaire Upgraded Inter Cooler Pump
Afco heat exchanger modified to accept AN connections
Trick Performance Stage III Inter Cooler
JDM Stage II heads & Cams
Comp Cams Adjustable Cam Spockets
JDM Ported Intake Manifold
Turkey Pan Delete Modified with divider
L&S Oil Separator
Navigator Cast Iron Block
Manley Coated Pistons
Manley I beam Rods
Cobra jet Crankshaft with dual keyway
Motor has about 1,500 miles rebuilt by local shop
Innovators West Balancer with Blower Drive (2, 4, 6. 8 Drive lower Pulleys)
Teflon Coated Bearings
Canton Oil Pan
JLP Comp R Exhaust with Spin Tech Cat back (No Cats)
JLP Intake with Ram Air
Twin 75 mm Ford GT Throttle Body Rebuilt by Kenny Bell
Kenny Bell 2.6 H Rebuilt by Kenny Bell Less than 1,000 miles
Custom 3.0", 3.25", 3.5", & 4.0" Upper Pulleys
JLP Power Flow Plenum
JC Customs Blower Mid plate for Trick Intercooler with 3/8" spacer
Magnum Power Idler bridge with (3) 100 mm Dual Bearing Idler Pulleys
280 Amp Powermaster Powder Coated Alternator
All New ARP bolts according to 0356 harley's list Including blower Studs & cap Screws
Custom Leather Bucket Seat Conversion
2fast4u Custom Center Console
Custom Sound Deading on the entire Cab
Custom Alpine, Audison, Focal Car Audio system with Custom 12" Subbox
New Black Carpeting
Overhead Gauge, and Dashboard Circuit boards resoldered
New Headliner
Custom Dash Cover to mount (3) gauges (Fiberglassed in)
This is all I could Think of at the time
Parts: I have to install or lying around
Original Drive Shaft, Blower, throttle body, grilles, leaf springs
New Raptor Electric Fans (still in the box)
New 0356 Harley's Raptor Fan wiring Kit, & fuel pump relay wiring kit
New 8 gallon bed mounted intercooler tank
New Mezzaire 56 gallon per hour pump
SCT 3000 tuner
Misc AN Fittings & Hoses to mount new intercooler system
Fiberglass roll pan
Truck has not run since November 2021
Tired of it taking space LOL
near New Orleans, LA
$15,000 takes eveything
no trades at this time
If you have any interest in parting it out I'm looking for a Kenne Bell 2.6, fiberglass leafs, powerflow plenum, raptor fans. I'm over on the FL panhandle and could drive out that way so not needing to ship...
Im interestes. Where are you located? I may have missed it, sry
Edit:found it
just had the truck towed to my house
Sitting since last November interior is moldy, have to clean
Motor installed with new intercooler, need to mount the blower, intake adapter
Not interested in parting out at this time, just want the whole thing gone
all parts are installed on the truck except:
8 gallon intercooler tank
JC custom front mount Intercooler tank
intercooler hoses
the heat exchanger
heat exchanger pump
raptor fans & harness
original parts that were left
pictures coming as soon as my phone charges
1 - 9 of 9 Posts
