1 - 20 of 42 Posts
Tongue Puncher
$10,800... Firm.
2001 Ford Lightning - SVT F150
Build #1,910
5.4L s/c, 4R100 trans
Silver paint, grey & black interior - no scratches, dents, or dings... very small rock chip here or there.
Link to 37 High Res pics: Click the thumbnail:
Mods:
-JDM Engineering dyno tune (very conservative - 380/515 to the tires)
-SCT Xcal3 tuner
-6psi lower pulley, 2.8" upper pulley (about 14.5 lbs boost)
-AutoMeter Lunar boost/vaccuum gauge in steering column pod
-Dantes Modular Performance "progressive" valve body in transmission (awesome shifts - fast & firm, shifts get harder as load/rpm increases)
-EGR delete
-JDM Engineering cold air intake
-Bassani off-road midpipes (no cats)
-Magnaflow catback
-Lightning Force Performance heat exchanger (fabbed aluminum single-pass)
-Belltech 2" drop coil springs (front)
-Belltech 2" drop hangers (rear)
-Line lock
-Traction bars (slapper-style)
-15% tinted windows
-Pioneer double-din head unit w/ DVD player
-Infinity Kappa 6x8's (4)
-Alpine "V-Power" amp
-Factory wheels stripped and powdercoated gloss black
-Bedrug
-shorty antenna
-Sylvania Silverstar bulbs in heads & fogs
-Expedition door handles (no key holes)
-03/04 steering wheel (perforated)
-Newer taillights and front corners from a low mileage L.
Maintenance:
-Trans flush 2x in past 18 months (overkill, but I like to make sure it's always fresh)
-Cooling system serviced/flushed
-Rear flushed, filled with Royal Purple & friction modifier
-religious oil changes
-fuel filter
-Ford OEM c.o.p.'s (all 8, installed 11/22/10)
-spark plugs (NGK TR6)
-Brakes- 4 new Ford OEM rotors, Hawk HPS pads
-wheel bearings (inner & outer)
-axle seals
-new front bump stops (shaved 50% to allow sufficient suspension travel)
-new shocks (all 4)
-new tires (all 4)
-new vaccuum lines
-new O2 sensors (2)
-re-painted: front bumper, all ground effects, rear bumper. (all had rock chips)
Other info:
-Seats are in great condition, but there's a small wear spot on the driver side thigh bolster.
-I slid off an icy road in February at low speed. Hit a street sign and it scraped the bumper cover. Insurance paid for a new front bumper cover, then I paid to have the rest of the parts repainted (to get rid of the normal rock chips from everyday driving)
My truck is very conservatively tuned. I drive it daily as a commuter car and don't race... so I wanted it to be reliable & safe. There's very little timing in it, maybe 12*. This tune made 380rwhp & 515rwtq. If you up the timing and get more aggressive, it shouldn't have a problem safely making 430-440rwhp.
I bought this thing with 110K on the clock. Re-did everything on it to make sure it was correct. Performed all maintenance work. This thing is ready to go... really. Just get in and drive. No issues.
129,700 miles.
under carriage/interior/engine bay pics??
Tongue Puncher
Discussion Starter #4
I'll get some up as soon as possible.
I got the truck out of Kansas, so it hasn't been subjected to the harsh NJ winters and salt. The chassis appears to have had undercoat from day one. Some worn spots are showing very little surface rust, and that's on the inside of the frame rails in few spots. The underside of this thing is good to go. No leaks, seaps, drips, drops, nothing.
Interior: the gray carpet is starting to show its age. I have a brand new black ACC mass-back carpet here for it, with new Chikenears black mats with silver embroidery. They go with the truck.
I'll get pics up sometime tomorrow if the weather cooperates.
GLWS... My truck is at 171,000 miles and you can eat of it. Thought about selling it but I think I just gonna keep it.
Your price is decent and you should get a buyer quickly.
Tongue Puncher
Discussion Starter #6
Thanks Rgig. If it sells, it sells... if not, I get to drive a clean, reliable, bada$$ truck for a while longer :)
Here's a few interior & engine bay shots. The weather sucked today, so I'll get some exterior shots in a few days.
was it ever in a flood???
and why is the MAF "clocked" wrong?
Tongue Puncher
Discussion Starter #12
No floods, fires, natural disasters, or other acts of God.
The MAF is seated in a position where it will get the best reading. It was clocked when the filter & adapter were installed. It was then dyno'd same day.
Tongue Puncher
Discussion Starter #14
VIN: 2FTZF07371CA55481
Yes, sir... clear title. I have the CarFax from when I bought the truck. The only issue that would show up is the incident that I described in the ad. I slid off the road in bad weather 2/2010... struck a sign post and had insurance replace the front bumper cover.
No flood damage, no thefts, no fire, no nothing.
I have the Ford OASIS report, too. Here's the warranty claims:
-Nov '02: fuel pump replaced
-Jan '04: power steering pump replaced
-Oct '04: pinion bearings, pinion seal, and tracloc clutches replaced
-Oct '04: left front lower control arm replaced due to missing steering stop
-Oct '04: transmission output seal replaced
-Feb '06: cruise control harness replaced
Tongue Puncher
Discussion Starter #16
Bout a two hour ride, give or take. Depends on where you're at. I'm in 07728. You'd come north on the NJ Turnpike to exit 7a, then take 195 East to exit 28b. I'm only a few miles from there.
1 - 20 of 42 Posts
