whipple pulley - Lightning Forum | LightningRodder.com
Go Back   Lightning Forum | LightningRodder.com > The Creations... > Gen 2 Lightnings
Official Supporting Vendors
Advertisements
Reply
Thread Tools Display Modes
Old 03-20-2011, 02:39 AM   #1
superfox
Senior Member
superfox's Avatar
superfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond reputesuperfox has a reputation beyond repute
Default whipple pulley
hi guys
what the pulleys combo for whipple 2.3L to get 18 psi ?
Is it safe to run 18psi on 93oct pump gas ?
i have 4#,6# lower Rings ,big TB , TF heads,built engine ,and full catback
whipple told me lower 4# with 3.125 is 18psi that correct ?
__________________
#2652 2001 ,WHIppLe 2.3L,TF heads ,OBX Lt`s,magnaflow exhaust, Drop sheckles 2 inch , HiD 6000k Heads light & Fog`s,Black tail light, AFCO HE+Fan,TF Ic tank , 160* stat
STATE OF KUWAIT
superfox is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-20-2011, 06:50 AM   #2
ThunderBolt
THE REPUBLIC OF TEXAS
ThunderBolt's Avatar
ThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond reputeThunderBolt has a reputation beyond repute
Default
You're looking at an 8# lower and 3.375 upper to make 17 - 18#'s on a fully built motor. What size of pulley is on your Whipple?
__________________
ThunderBolt is offline   Reply With Quote
Old 03-20-2011, 08:20 AM   #3
superfox
Senior Member
superfox's Avatar
Default
whipple pulley 3.375 , i want change the upper i can find them easy on kuwait ,,the lower ring i need to order it from usa and wait long time
__________________
STATE OF KUWAIT
Old 03-20-2011, 08:25 AM   #4
castellscl
Senior Member
castellscl's Avatar
castellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond reputecastellscl has a reputation beyond repute
Default
You many run into to some belt slip problems trying to find a small enough upper pulley to get that kinda boost with a 6# lower.
__________________
castellscl is offline   Reply With Quote
Old 03-20-2011, 08:26 AM   #5
castellscl
Senior Member
castellscl's Avatar
Default
I'm running a stock whipple upper and an 8# lower and barely see 18# on a cold day.
__________________
Old 03-20-2011, 08:46 AM   #6
svtlightning02
10 Second Club!!!
svtlightning02's Avatar
svtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond reputesvtlightning02 has a reputation beyond repute
Default
my motor only has 300 miles on new build but im running 8lb lower and 3.375 upper and i havent held truck to see how much boost it makes but if you just slap the loud pedal it jumps to 15lbs instantly. there are other variables that come into effect also
__________________
02 TRUE BLUE #4069
BUILT AND TUNED BY JDM
2.3 WHIPPLE- 10.61 @129
2012 4Door 4x4 F150 5.0
35" Open Country MT's
Lightning Hauler
svtlightning02 is offline   Reply With Quote
Old 03-20-2011, 11:01 AM   #7
SVTBandit
Senior Member
SVTBandit's Avatar
SVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond reputeSVTBandit has a reputation beyond repute
Default
8lower and 3.375 upper I see 17 pounds
SVTBandit is online now   Reply With Quote
Old 03-21-2011, 02:30 PM   #8
superfox
Senior Member
superfox's Avatar
Default
guys what the size belt .3.375 and the lower 8#?
__________________
STATE OF KUWAIT
Old 03-21-2011, 03:38 PM   #9
Certified Drunk
10 Second Club
Certified Drunk's Avatar
Certified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond reputeCertified Drunk has a reputation beyond repute
Default
Quote:
With the stock idlers I bought a 69.625 and it was tight, 70" would be perfect.
__________________
Certified Drunk is online now   Reply With Quote
Old 03-21-2011, 04:57 PM   #10
J.R.
aka Nivardo
J.R.'s Avatar
J.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond reputeJ.R. has a reputation beyond repute
Default
Quote:
Ron I have a 6lb lower (9.25") and a 3.5 upper full 3" exhaust making 16lbs.....
J.R. is offline   Reply With Quote
Old 03-22-2011, 05:45 AM   #11
superfox
Senior Member
superfox's Avatar
Default
Quote:
what is your rwhp on 16psi ?
__________________
STATE OF KUWAIT
Old 03-22-2011, 06:36 AM   #12
Got Boost
Mr. Crossfire
Got Boost's Avatar
Got Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond reputeGot Boost has a reputation beyond repute
Default
8lb lower and stock upper on my lil whipple, 16-17lbs
__________________
Stock Block Whipple. (WMS Tuned)
7.11@95.50MPH/11.21@121MPH All Boost
http://www.youtube.com/watch?v=OD4t-8Z8VKc
http://www.youtube.com/watch?v=WgKPhBArBsw
1.45 60ft, 6.49 1/8th, 10.24@131 All Boost (WMS Tuned)
10.24 video, http://youtu.be/02xf9CmuxWA
2013: Under construction
Got Boost is offline   Reply With Quote
Old 03-22-2011, 07:03 AM   #13
J.R.
aka Nivardo
J.R.'s Avatar
Default
610hp/630tq
Old 03-22-2011, 11:21 AM   #14
castellscl
Senior Member
castellscl's Avatar
Default
610hp/630tq
DAM!
What other mods you running:
Cams
Heads
Timing
fuel
Giggle Gas?
__________________
Old 03-22-2011, 04:01 PM   #15
J.R.
aka Nivardo
J.R.'s Avatar
Default
Quote:
Originally Posted by castellscl View Post
DAM!
Cams
Heads
Timing
fuel
Giggle Gas?
It's all in my sig. 12* of timing. 93 octane
But now that I think of it, it was at 16lbs before I had to gut the cats, so it should be lower now. Anyone know about how much lbs of boost you loose after goin catless?
Reply
Advertisements
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
