Minimum Tire Lug Thread Engagement - Lightning Forum | LightningRodder.com
Go Back   Lightning Forum | LightningRodder.com > The Creations... > Gen 2 Lightnings
Official Supporting Vendors
Advertisements
Reply
Thread Tools Display Modes
Old 07-08-2010, 08:21 PM   #1
jwlast
Senior Member
jwlast's Avatar
jwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond reputejwlast has a reputation beyond repute
Default Minimum Tire Lug Thread Engagement
After buying a set of new 16" 11" wide Bogart D-10 rear rim's and installing a 7/16th spacer due to tight tire clearence with the leaf springs, I noticed the lug's only go on a total of 6 turn's on the stock studs for a 2004 Lightning. They are open ended lug nutz that sit flush with the end of the stud when installed and torqued down (see pics). They torque up to spec, and seem very sturdy.
I heard the rule of thumb is that 2 threads should be showing thru the end of the lug nutz when properly torqued (using 100 ft lbs). I don't want to wreck myself , someone else, or the truck over something as basic as some lug's nut's that aren't engaging the thread's enough.
Seems like its on the minimum verge of being safe. Any thoughts?
Thanx
JT
__________________
"Don't discount the possibility ..."
Sorry, discount already taken.
jwlast is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-08-2010, 08:35 PM   #2
boostaholic01
Senior Member
boostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond reputeboostaholic01 has a reputation beyond repute
Default
im pretty sure its either ihra or nhra rules or maybe both say that the stud has to come out so far past the lugs... i think its twice the with of the stud... that was the rule a long time ago. either way they dont work on your truck so just send me those useless wheels and il put them to use lol
boostaholic01 is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 08:39 PM   #3
louisianaSVT2001
Nothing burps better than bacon
louisianaSVT2001's Avatar
louisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond reputelouisianaSVT2001 has a reputation beyond repute
Default
I've always heard the 2 full threads out rule
__________________
JLP Long Block, CNC Heads, Stage 3 Cams, 2.6KB, LFP single blade TB, JLP thunder tube and race air box, 80lb injectors, aeromotive FPR, 97 rails, 255 Walbros, BTS Trans and PI 2400 converter, 3" Bassani Comp R exhaust, massive traction challenges.
http://youtu.be/7Ny-Rwzcesw
louisianaSVT2001 is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 09:28 PM   #4
Scuba-Matt
Boost Freak!!!!!!!!
Scuba-Matt's Avatar
Scuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond reputeScuba-Matt has a reputation beyond repute
Default
From the NHRA rule book
The thread
engagement on all wheel studs to the lug nut, or lug bolt to wheel
hubs, must be equivalent to or greater than the diameter of the
stud. Length of the stud/bolt does not determine permissibility;
length of the engagement between the stud and lug determines
permissibility.
__________________
2012 Lava Red 2.3 TVS Super Charged Mustang GT
7.5 PSI Boost
10.16 @ 137 MPH
Scuba-Matt is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 09:48 PM   #5
jwlast
Senior Member
jwlast's Avatar
Default
Quote:
The thread
permissibility.
WTF? In plain english........(BTW, thanks for the quote, just wish I was smart enuff to understand what it's trying to say) I finished in the bottom 15% of my high school class, but I did have good hand-eye coordination.
__________________
Old 07-08-2010, 10:51 PM   #6
exracr
JLP Stage 3 XR heads, MP@19psi
exracr's Avatar
exracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond reputeexracr has a reputation beyond repute
Default
The thread
permissibility.
go look at ANY stock L rims with lugs.... and I bet the don't stick out that far!
soooo many rules in NHRA..
__________________
Has the one of a kind hidden B00bie magnet installed!
My hankooks hate me!
exracr is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 11:02 PM   #7
Soccman
Ford Certified Technician
Soccman's Avatar
Soccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond reputeSoccman has a reputation beyond repute
Default
damn it man if you have to get longer studs... thats a job in itself. looks like your in the market for some slightly narrower tires
__________________
RED 2000 #1623, Going Built, GT500 Crank, Manley platinum series coated pistons, Manley H-beam rods, Trickflow 185 Trackheat heads(9.5:1), Bullet .550 lift cams, Full ported/polished intake, Race ported Eaton, 10lb lower, SBTB, Open element filter, 3/4in intercooler lines, Walboro 255s, 60lb injectors, Cat-less Full OBX LT exhaust, Circle D 2500 stall, SCTX4, 2in drop, BroncoBeater(longbars, panhard, DS loop), True Forged 20s.....
Soccman is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 11:24 PM   #8
SHOKDU
Boost-A-Holic
SHOKDU's Avatar
SHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond reputeSHOKDU has a reputation beyond repute
Default
Quote:
It means that you need approximately 1/2" of threads showing through the nut on the stud.
__________________
Owner: Mark H. #3496 of 4966
Built by ME. Tuned by DMP
21 psi, 18* timing, C-16, 651 HP / 737 TQ
sig by: s|ck
SHOKDU is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 11:27 PM   #9
exracr
exracr's Avatar
Default
on aircraft... military aircraft capable of going Mach 2.5 and 9+ G's... rule is ALL hardware must protrude 2 to 3 threads past surface!
__________________
Old 07-09-2010, 12:09 AM   #10
roach4047
Fat Bastad
roach4047's Avatar
roach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond reputeroach4047 has a reputation beyond repute
Default
The tech guys at my local track simply stated that the lugs had to extend past the nuts. If you're running slicks you're also required to use open ended lug nuts such as the ones you have pictured as well vs a set of closed ended such as the oem nuts. Open ended nuts aren't a requirement if running DOT tires but then the tech might want to inspect all of your lug bolts in order to ensure they're of a proper length so why chance it.
Roach
roach4047 is offline   Reply With Quote Quick reply to this message
Old 07-09-2010, 12:14 AM   #11
Dash808
Flyin HI
Dash808's Avatar
Dash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond reputeDash808 has a reputation beyond repute
Default
Just cut the nut down.
jk jk!
Dash808 is offline   Reply With Quote Quick reply to this message
Old 07-09-2010, 05:48 AM   #12
SnipeJDM
Senior Member
SnipeJDM's Avatar
SnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond reputeSnipeJDM has a reputation beyond repute
Default
As long as all the threads in the nut are engaged, you are fine. Should be fine with NHRA too. If there is any doubt, take your spacers to a machine shop and have them mill them down 1/16"-1/8"
__________________
Old Setup - Eaton, 2lb lower, 2.93" upper, 12.93@105
New Setup - KB2.3, 4lb lower, 3.25" upper, 435/510 - 12.48@109
SnipeJDM is offline   Reply With Quote Quick reply to this message
Old 07-09-2010, 08:52 AM   #13
bet on black
El duderino
bet on black's Avatar
bet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond reputebet on black has a reputation beyond repute
Default
Quote:
how i read that is that you need at least 14mm of threads engaging in the nut. if the stud is flush with the outside of the lug nut, and the lug nut is at least 14mm thick then you should be fine. you may have been saying the same thing, i couldn't really tell
__________________
'03 black turbo L
'04 caddy cts-v - the daily
'13 f250 - 6.7L ccsb 4x4
'59 chevy apache 36
'00 Aprilia Mille RSV 1000 R
'05 harley sportster xl1200c
'01 f250 platinum edition - 7.3L diesel crew cab 4x4 - STOLEN & STRIPPED 10/2014
'77 kawi kz650 -bobber project
bet on black is offline   Reply With Quote Quick reply to this message
Old 07-09-2010, 09:04 AM   #14
Scuba-Matt
Boost Freak!!!!!!!!
Scuba-Matt's Avatar
Default
The rule means that if the stud is 1/2 thick that is how much must stick out past the lug nut. If the stud is 14mm thick (.55 inches), then 14mm 0r .55" must be visible past the nut.
__________________
7.5 PSI Boost
10.16 @ 137 MPH
Old 07-09-2010, 09:12 AM   #15
bet on black
El duderino
Default
engagement does not mean protrusion. i disagree with your interpretation, respectfully of course.
__________________
'03 black turbo L
'59 chevy apache 36
Reply
Advertisements
Bookmarks
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Lightning Forum | LightningRodder.com forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
