03 lightning supercharger pulley - Lightning Forum | LightningRodder.com
Go Back   Lightning Forum | LightningRodder.com > The Creations... > Gen 2 Lightnings
Official Supporting Vendors
Advertisements
Reply
Thread Tools Display Modes
Old 03-13-2010, 12:56 AM   #1
SVTPhilly931
Senior Member
SVTPhilly931's Avatar
SVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond reputeSVTPhilly931 has a reputation beyond repute
Default 03 lightning supercharger pulley
Fellas, I just bought a 2003 Lightning.. Around the pulley and belt there is a rust looking dust .. is that from the belt slipping on the supercharger ? Should i replace the pulley with a better non slip one ? and a new belt to be safe ?
SVTPhilly931 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-13-2010, 12:59 AM   #2
mrcarbine
Boostaholic
mrcarbine's Avatar
mrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond reputemrcarbine has a reputation beyond repute
Default
Quote:
belt slip will usually leave black soot but I suppose it could turn different colors. do you have the stock pulleys or are you running aftermarket pulley(s) If your running aftermarket I would get an idler setup just for piece of mind. You wanna make sure you get every lb of boost that your paying for
__________________
THE BUILD IS OFFICIALLY UNDERWAY! Coming Spring of 2010: JLP shortblock, KB 2.6h, Comp Cams Stage 3 Cams/Springs/Retainers, OBX Longtubes/Mids, Circle D 2400 Stall, and whatever else I can afford and get my grubby little hands on
mrcarbine is offline   Reply With Quote Quick reply to this message
Old 03-13-2010, 12:59 AM   #3
stoffer
I'm not banned, I just don't post
stoffer's Avatar
stoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond repute
Default
what size is the pulley?
__________________
stoffer is offline   Reply With Quote Quick reply to this message
Old 03-13-2010, 01:00 AM   #4
lightningkylej
CORNFED
lightningkylej's Avatar
lightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond reputelightningkylej has a reputation beyond repute
Default
The dust is probably just that, dust. Belt dust is a dark grayish black. As far as I have heard, there is not a magic pulley that is more non-slip than any others. The best way to reduce slip is to add an auxilary idler setup that will increase belt wrap around the upper pulley.
What pulleys are currently on the truck (upper size and lower size)?
__________________
First Gen II Lightning running on E85! Built motor, Turbo Blown
lightningkylej is offline   Reply With Quote Quick reply to this message
Old 03-13-2010, 01:03 AM   #5
cacric
PAY UP SUCKA!!!
cacric's Avatar
cacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond reputecacric has a reputation beyond repute
Default
Another tell tale sign of the belt slippin is to look at the underside of your hood right about where the belt is lined up.......if you see a build up of gunk then you are slippin.
__________________
cacric is offline   Reply With Quote Quick reply to this message
Old 03-13-2010, 01:03 AM   #6
stoffer
stoffer's Avatar
Default
I'm content with the riechard pulley for my procharged truck
__________________
Old 03-13-2010, 01:31 AM   #7
mrcarbine
Boostaholic
mrcarbine's Avatar
Default
Im thinking maybe he is just seeing some muddy/dirty water kicked up from driving in rain and shit but we wont know till some pics are posted (hint hint)
__________________
Old 03-13-2010, 01:35 AM   #8
lightningkylej
CORNFED
Default
Quote:
Despite that being for a procharger instead of the eaton, it is a nice looking pulley. I was just refering to what the OP would use. If we wanted to get really anal about eliminating slip, GO COG, nuff said!
__________________
Old 03-13-2010, 01:37 AM   #9
stoffer
stoffer's Avatar
Default
riechard makes 'em for the eatons, but personally yeah I'll go cog if I have any belt slip with the eaton
the "stock" ATI belt drive for the 2 valve F-150's makes me cringe just thinking about how pathetic it really is
__________________
Old 03-13-2010, 05:19 AM   #10
Tigator
Senior Member
Tigator's Avatar
Tigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond repute
Default
I remember looking at a '99 before I bought my '01 L and noticed the top pulley was rusty. I think I kept some picts of it. Let me see. Could this be what he sees? Note: this '99 Sold in Clinton and went to Gretna.
__________________
2001 Ford SVT F150 White Lightning
#2161 of 6381 Build Date: 3/23/01
OBX SS Headers mids, AeroChamber Mufflers
FTVB, 2in drop shackles, EGR delete, TR6's,
K&N CAI, C&L, 555R'S, Cervini hood and spoiler,
4# pulley, Aeroforce,
Moats.net F8 - 8 position chip,
Tigator is offline   Reply With Quote Quick reply to this message
Old 03-13-2010, 05:33 AM   #11
infinite_one
Supporting Member
infinite_one's Avatar
infinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond reputeinfinite_one has a reputation beyond repute
Default
thats not a stock pulley, and it must be steel, i believe the stocker is aluminum
__________________
-Joe
2001 #344
few bolt ons, lowered, built trans and the typical cosmetic mods
other rides:
88 iroc vert (real clean, mostly stock)
01 gtp coupe (built everything low miles runs 12's) <<under construction
08 ram sport QC (insert list of complaints about it here)
infinite_one is offline   Reply With Quote Quick reply to this message
Old 03-13-2010, 05:33 AM   #12
infinite_one
Supporting Member
Default
could be wrongm thoguh
__________________
-Joe
2001 #344
other rides:
Old 03-13-2010, 02:43 PM   #13
stoffer
stoffer's Avatar
Default
that '99 needs some lovin
__________________
Old 03-13-2010, 06:07 PM   #14
OldTimer
Even Then I Was Old Skool!
OldTimer's Avatar
OldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond reputeOldTimer has a reputation beyond repute
Default
Stocker is steel, but that's not a stocker... it doesn't have those holes. Its aftermarket with a bad paint job prep. I have the 2.76" Billetflow on my Eaton for 2 years now and while it was goo by itself... it seemed to be even better when I added the Metco Idler with 100mm idler pulleys. No slip now.
But was the OP talking about upper or lower? Lower pulley is also steel... I just checked my parts box with a magnet.
__________________
Click Either of the Two Links Below For More Information On:
OldTimer is offline   Reply With Quote Quick reply to this message
Reply
Advertisements
Bookmarks
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Lightning Forum | LightningRodder.com forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
