How to test Ford Coil on Plug Packs - Lightning Forum | LightningRodder.com
Go Back   Lightning Forum | LightningRodder.com > How To & Tech > Gen 2 & Harley "How-To's"
Official Supporting Vendors
Advertisements
Reply
Thread Tools Display Modes
Old 10-18-2007, 05:39 PM   #1
Bgstew6
DONE
Bgstew6's Avatar
Bgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond repute
Default How to test Ford Coil on Plug Packs
with an Ohm meter and the coil on plug pack out of the truck...
Check the Primary circuit by simply taking the pos test lead and attach/touch it to one connector terminal and at same time attach/touch the neg test lead to the other. Measure the ohms and ensure you are seeing at most 5.5k Ohms
Also check the secondary circuit of the Coil on plug pack by touching the pos lead to one of the primary pins and the neg lead to the spring in the boot of the pack. Measure the ohms and ensure that .5500 Ohms.
Primary 5.500 k-ohms
secondary .55 ohm
this will work is the CP is dead....not one that is intermittent or starts acting up after it gets heated up or failing under load. FOrd makes a nice diagnostic tool that can diagnose problems like this.
__________________
2k2 Black Harley Davidson SCrew, #1088
What's that sound you say????...."Why that's 19lbs of Pure, Cogged, Kenne Bell 2.3 Screamin Hell! mixed with a little bit of my Stock Block crying like a Jilted Jezebel
"If you know the enemy and know yourself, you need not fear the result of a hundred battles. If you know yourself but not the enemy, for every victory gained you will also suffer a defeat. If you know neither the enemy nor yourself, you will succumb in every battle."
- Sun Tzu
How come these injuns ain't killin us???
Cause they can't see us, we're in the spirit world asshole!!!
My Gallery
Bgstew6 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-17-2011, 07:09 PM   #2
costrsupt
Senior Member
costrsupt's Avatar
costrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond reputecostrsupt has a reputation beyond repute
Default
And what is said diagnostic tool?
__________________
2002 Harley Davidson 150: Punisher VB, 4X4 trans pan, K&N CAI, C&L Elbow, C&L Plenum, Polished Accufab SBTB, EGR delete,Oil separator, Lightning upper pulley,Ported Eaton, Ported Mid plate, Trick 2 gal I/C tank, LFP Tri-Y longtubes with full magnaflow exhaust and x pipe(Lightning exit). SCTX3, Dynojet WBC, duel 255's, 6lb lower, and BA2400 MAF. Tuned buy Amazon.
costrsupt is offline   Reply With Quote Quick reply to this message
Old 01-17-2011, 07:30 PM   #3
Bgstew6
DONE
Bgstew6's Avatar
Default
bout a 5k diagnostics tool (Ford IDS)
__________________
- Sun Tzu
My Gallery
Old 01-17-2011, 07:35 PM   #4
MPORTETR
Cogged Carolina Lightning Rodder
MPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond reputeMPORTETR has a reputation beyond repute
Default
Nice write up! Thanks Stew!!!
__________________
[URL="http://www.lightningrodder.com/forum/showthread.php?p=1390569#post1390569"][IMG]http://www.lightningroddergallery.com/data/639/SVTSIG4.jpg [/IMG][/URL]
[COLOR=orange][SIZE=2](For how-to help [COLOR=red]click[/COLOR] on my Sig above)[/SIZE][/COLOR]
Not my real rims...Polished Throttle Bodies are out of my price range...Sig by rman
[CENTER]BUILT by BOOSTED PERFORMANCE...TUNED by AMAZON TUNING SOLUTIONS[/CENTER]
[CENTER]syndicate, noun |'sindikit| a group of individuals, organizations or criminals combined to promote some common interest. [/CENTER]
[CENTER][IMG]http://www.lightningroddergallery.com/data/639/boobies.gif[/IMG]This post was sent via [COLOR=lime]Alienware or Android[/COLOR][IMG]http://www.lightningroddergallery.com/data/639/lo.gif[/IMG][/CENTER]
[QUOTE=lightninquick;1398184]a guy wants a Bult motor for free
two guys have their pants off
another couple guys want to smoke bud
the rest are drunk
one is drunk dreaming of bud with two guys with their paints off, one with a gun
sounds like just another day on lightningrodder[/QUOTE]
MPORTETR is offline   Reply With Quote Quick reply to this message
Old 01-17-2011, 07:39 PM   #5
costrsupt
Senior Member
costrsupt's Avatar
Default
Quote:
Lol so if I have an intermittant problem with one I cant find its cheaper to just buy a whole new set
__________________
Old 01-17-2011, 07:40 PM   #6
Bgstew6
DONE
Bgstew6's Avatar
Default
Quote:
or if you have a buddy at Ford he can hook it up and run and iNdividual cylinder performance test
__________________
- Sun Tzu
My Gallery
Old 01-18-2011, 03:59 AM   #7
Tigator
Senior Member
Tigator's Avatar
Tigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond reputeTigator has a reputation beyond repute
Default
As someone once told me recentely here after trying to explaining something to them...
Now I'm really lost.
What happened to the day when 1 freakin coil fires All the freakin plugs? 8's and high 7's were attained like that.
Sorry, I am from the keep it simple stupid school.
Thanks Stew L veteren, one day I am going to need this info but for now I will stick with my stock cop's and cross my fingers and toes. Some stuff is over my head but it is a good read.
__________________
2001 Ford SVT F150 White Lightning
#2161 of 6381 Build Date: 3/23/01
OBX SS Headers mids, AeroChamber Mufflers
FTVB, 2in drop shackles, EGR delete, TR6's,
K&N CAI, C&L, 555R'S, Cervini hood and spoiler,
4# pulley, Aeroforce,
Moats.net F8 - 8 position chip,
Tigator is online now   Reply With Quote Quick reply to this message
Old 01-18-2011, 10:26 AM   #8
xonecrazyx
Senior Member
xonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond reputexonecrazyx has a reputation beyond repute
Default
each coil is fired just after injector fires . reason most people change all
__________________
xonecrazyx is offline   Reply With Quote Quick reply to this message
Old 01-18-2011, 10:42 AM   #9
xonecrazyx
Senior Member
Default
because if one is failing why do 1 at time . unless new. just change all
__________________
Old 02-06-2011, 03:02 PM   #10
MattACK
Supporting Member
MattACK's Avatar
MattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond reputeMattACK has a reputation beyond repute
Default
In my experience I had 2 COPs fail in my 2000 F150 at once. No reason to replace perfectly good COPs. That'll be like replacing all 4 tires if you get a flat.
__________________
|'03 Sonic Blue Lightning|
Just another 10 second street truck [MODS]
Tuned by by me with help from the world renowned nozamakcuf!
10.8 @ 125mph
|'03 Redfire Cobra|
STOCK... for now.
View this section of the forum before using AMAZON TUNING SOLUTIONS ---> [VENDOR FEEDBACK FORUM]
MattACK is offline   Reply With Quote Quick reply to this message
Reply
Advertisements
Bookmarks
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Lightning Forum | LightningRodder.com forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
