#1 |
Founder/Owner
![]() Join Date: Sep 2004
Rep Power: 71583090 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() INFO FROM "CHUCK'S LIGHTNING PAGE" For those that have never seen it, IT'S AMAZING SEE IT HERE (AND WORTH PUTTING IN YOUR FAVORITE FOLDER) THANKS CHUCK The boost actuator is located on the driver's side of the intake close to the firewall. There are (2) 10mm bolts that hold it in place. One you can see in the pic and the other is on the backside of the actuator closest to the firewall. Pay attention to the slots location in reference to the bolts so you will know where you started. Loosen bolts and raise the actuator up until you see the LEVER raise up off of the STOP. Lower it back down until the LEVER just touches the STOP then tighten bolts. Now, this is the way it was explained to me but I found that set this close the boost gauge would rise to almost "0" while cruising at 80. I went back and readjusted so I could cruise at 80 with no needle movement unless I barely moved the throttle (and I mean barely). This setting was probably halfway between the stock setting and the just touching setting. The first thing I noticed was the needle jumped immediately to 10lbs and climbed from there. Stock it jumped to 9.5lbs and climbed. The total boost also increased by a 1/2lb to 1/4lb more. I also ran a tick quicker with my fastest mph at the track. The temps were warmer and there was less traction (it rained until the track opened). I think this adjustment is worth a small amount of speed. Besides, it's free.
__________________
***** COBRA, "THE OTHER WHITE MEAT" ***** ![]() 03 Cobra, Built Motor, KB 2.8H, PA 4r70w, PI 3500 Triple Disc Lockup Conv PI Manual Valve Body, Transbrake, 8.8 SRA Rear, 3.73 Gears, Eaton Posi, Moser 31 Spline Axles, AND A LOT MORE... Details Here -- Fun Vid Here Black 02 Sold 6/6/6 - Red 99 Sold 2/2/7 - Black 00 Sold 12/29/9 - |
#2 | |
Supporting Member
![]() Join Date: Oct 2004
Rep Power: 10239622 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Quote:
Some good useful info on this forum LightningRodder
__________________
LIGHTNING FAST<br />2003 LIGHTNING <br />POWERED BY JDM BUILT LONG BLOCK<br /> TUNED BY RICK AMAZON |
#3 |
I got my money back
Rep Power: 71584403 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
many thanks rob
__________________
parts for sale with pics (updated on 23 June 2010) http://www.lightningrodder.com/forum...201#post635201 ![]() sig thanks to Watson91 @ http://screen-fx.net/forum/index.php - '03 Harley Davidson Edition - shows in stock class - worlds first snake bit Harley Truck - '01 Lariat -F-150 supercab - procharged @15#, full Lightning suspension, and much more coming - Eddie Bauer Expedition - wife says "no boost" and claims she's serious |
#4 | |
TimmyMac's biological father.
Rep Power: 71582992 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
dang it. I can't get to the bolts because of the egr wires/lines
__________________
Joe ![]() *03 SVT Lightning Build date 03/20/2003 Build# 2650 out of 4270 *06 CSRT8 Speakers for sale ![]() Quote:
#5 |
Senior Member
Rep Power: 24 ![]() |
i just did that couple of days ago and its a pita to to loosen them bolts! lol my hands are all cut up now! but worth it
#6 | |
adjusted it this weekend and I see no difference
__________________
#7 |
AKA LightningClint
![]() Join Date: Oct 2008
Rep Power: 59092927 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
is this the same for the KB?
__________________
![]() ![]() Specializing in custom one off aluminum products for your Ford Lightning, HD or Cobra. For orders or any other custom fabrication needs please contact me at hitmanfabrication@yahoo.com or give me a call (916)844-5908 KB 2.3 .......................2.6 w/JLP PF...............2.3 Whipple ![]() ![]()
#8 | |
Senior Member
Rep Power: 33198431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Quote:
would this cause my boost to only boost 2lbs if it is adjusted wrong??
__________________
tune by JJ@WMS |
#9 | |
I got my money back
Quote:
YES
__________________
#10 |
I got my money back
this is an easy adjustment, when I get home I will ppos tthe pics of how to do it on a stock engine with all the "stuff" in the way
__________________
#11 | |
Senior Member
Quote:
cool thanks i got my problem figured out a while back but thnks for the info
__________________
tune by JJ@WMS |
#12 |
Living the Dream..
Rep Power: 71582950 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Could this be causing my stumbling effect when I try and roll into the throttle and she is just getting into boost?
__________________
#13 |
Blown Twice....
![]() Join Date: Dec 2004
Rep Power: 65394543 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
is the lever barely resting on the stop (when the motor is off) ?
__________________
2k2 Black Harley Davidson SCrew, #1088 21lbs of Pure, Cogged, Magnum Power's Screamin Hell! "If you know the enemy and know yourself, you need not fear the result of a hundred battles. If you know yourself but not the enemy, for every victory gained you will also suffer a defeat. If you know neither the enemy nor yourself, you will succumb in every battle." - Sun Tzu My GalleryHow come these injuns ain't killin us??? Cause they can't see us, we're in the spirit world asshole!!!
#14 |
Living the Dream..
Yeah it looks like it's just sitting on stop...I am so confused with this issue I am having...
__________________
#15 |
power hungry
Rep Power: 8034208 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
well?
__________________
2003 Expedition: 5.4L, ported blower, 6lb lower, 3.25 upper, c&l plenum, stock airbox w/k&n panel, LFP SBTB, FTSP, removed front cats, Magnaflow 3" catback, 2006 F150 20's, Hawk brake pads, Drilled rotors, Eclipse AVN-5510, white face gauges, cobalt c2 boost gauge, 359 rwhp, 434 rwtq |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
