Lightning Forum | LightningRodder.com
Go Back   Lightning Forum | LightningRodder.com > The Creations... > Harley Davidson Edition F150
Reply
Thread Tools Display Modes
Old 07-31-2010, 01:52 AM   #1
nitrous2fast
Senior Member
nitrous2fast's Avatar
nitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond reputenitrous2fast has a reputation beyond repute
Default Motor fvcked up.
Well my motor decided to mess up today running down the highway. I think that I either have a burnt valve or a messed up piston ring. So I am now going to be installing a MP2 Mod-900 SB in a few weeks after get everything sorted out with my stock block.
I checked my plugs and it looks like I was running rich but none were flattened or any other mal-looking appearance. Sunday I will be doing a compression test to determine which piston's rings and/or valves are messed up. Wish me luck
__________________
____________
MP2 Performance ported Eaton; MP2 Performance ported TB and Plenum; of course ZEX nitrous kit
Metco Idler Relo; 8# lower one piece
-02 HD
-97 Trans Am WS6- Nitrous, long tubes, 3" Borla exhaust, 3.73 Motive gears, cust. tuned, Street Fire ignition
-07 R1-Lowered, exhaust
-97 Accord- happily my DD
nitrous2fast is offline   Reply With Quote
Old 07-31-2010, 09:04 AM   #2
stoffer
I need a lightning
stoffer's Avatar
stoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond reputestoffer has a reputation beyond repute
Default
while going built is never a bad thing, are you sure you hurt the motor???
__________________
parts for sale with pics (updated on 23 June 2010) http://www.lightningrodder.com/forum...201#post635201
sig thanks to Watson91 @ http://screen-fx.net/forum/index.php
- '03 Harley Davidson Edition - shows in stock class - worlds first snake bit Harley Truck
- '01 Lariat -F-150 supercab - procharged @15#, full Lightning suspension, and much more coming
- Eddie Bauer Expedition - wife says "no boost" and claims she's serious
stoffer is offline   Reply With Quote
Old 07-31-2010, 12:13 PM   #3
nitrous2fast
Senior Member
Default
Won't be fully sure until I get the motor apart. If it only fails a compression test on one side then I'll just pull that head to see what has happen to that head/piston.
__________________
____________
-02 HD
Old 07-31-2010, 12:15 PM   #4
CNY03HD
Senior Member
CNY03HD's Avatar
CNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond reputeCNY03HD has a reputation beyond repute
Default
Good luck, hope everything works out
CNY03HD is offline   Reply With Quote
Old 07-31-2010, 01:25 PM   #5
nitrous2fast
Senior Member
Default
Quote:
Thanks.
__________________
____________
-02 HD
Old 07-31-2010, 01:32 PM   #6
stoffer
I need a lightning
stoffer's Avatar
Default
are you running a larger than stock MAF???
__________________
Old 07-31-2010, 02:36 PM   #7
nitrous2fast
Senior Member
Default
Quote:
No, I think that I might have pegged the meter?! My MAF volts were fine before i had the blower ported more. I should have datalogged it but hey what ya gonna do? anyways I have a MAFi.a. but I didn't install it so go ahead.
I was running her kind-of rich because of the timing I had in it, so a pegged meter is looking more and more likely a cause. The thing that gets me is that she just started to not pull anymore, I drove it to the shop carefully. It idles and has good fuel pressure. The cats were only at 530F so that ruled out a clogged cat?
__________________
____________
-02 HD
Old 07-31-2010, 02:45 PM   #8
Bgstew6
Blown Twice....
Bgstew6's Avatar
Bgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond reputeBgstew6 has a reputation beyond repute
Default
if youre lucky you toasted a plug or two
__________________
2k2 Black Harley Davidson SCrew, #1088
21lbs of Pure, Cogged, Magnum Power's Screamin Hell!
"If you know the enemy and know yourself, you need not fear the result of a hundred battles. If you know yourself but not the enemy, for every victory gained you will also suffer a defeat. If you know neither the enemy nor yourself, you will succumb in every battle."
- Sun Tzu
My Gallery
How come these injuns ain't killin us???
Cause they can't see us, we're in the spirit world asshole!!!
Bgstew6 is offline   Reply With Quote
Old 07-31-2010, 02:52 PM   #9
stoffer
I need a lightning
stoffer's Avatar
Default
that's exactly what I was thinking...
__________________
Old 07-31-2010, 03:28 PM   #10
nitrous2fast
Senior Member
Default
I already checked them they look fine except for a little carbon buildup.
__________________
____________
-02 HD
Old 07-31-2010, 03:29 PM   #11
nitrous2fast
Senior Member
Default
heck I've got a set of BR7s that I could throw in.
__________________
____________
-02 HD
Old 07-31-2010, 07:43 PM   #12
Bgstew6
Blown Twice....
Bgstew6's Avatar
Default
Coil Pack could be on its way out also....
__________________
- Sun Tzu
My Gallery
Old 07-31-2010, 08:06 PM   #13
nitrous2fast
Senior Member
Default
Quote:
I was thinking maybe that but Ive done a plug change before and left a coil unplugged and it didn't run the way that it is now so I'm leaning away from that?
__________________
____________
-02 HD
Old 07-31-2010, 08:10 PM   #14
Bgstew6
Blown Twice....
Bgstew6's Avatar
Default
typically when they start to go out.....they show it in the upper RPM range and after they get hot.
You can sit there at idle and rev the motor and it wont miss but go out and drive her and when you put it under some heavy load it will start to miss
__________________
- Sun Tzu
My Gallery
Old 08-01-2010, 12:03 AM   #15
nitrous2fast
Senior Member
Default
Its not a miss, it seams like something is running against the motor. I checked my oil level and its extremely low. I think that when I got on it hard it, the oil pressure dropped enough to let the timing chain jump. Don't know yet but tomorrow I will check valve timing and do the comp test and check everything else I can. Oh If I put in gear and hold the brake and give it a little throttle it starts to smoke out of the exhaust, so that leads me to think messed up piston again? But wondering why its not smoking out of the pcv though if I did mess up a ring or crack a ringland?
__________________
____________
-02 HD
Reply
Bookmarks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
LightningRodder.com Copyright 2003-10, all rights reserved.Ad Management plugin by RedTyger
